Led lights from Amazon
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Noswar5, Feb 7, 2021.
  1. Feb 7, 2021 at 11:30 AM
    Noswar5
    Noswar5 [OP] Member
    Macedonia Ohio
    2017 inferno Tacoma TRD
    I tried to install Led lights i purchase from Amazon the 1st one I installed in the map light blew the fuse. I changed the fuse and it shorted out the whole control panel for the sunroof,traction control. Etc. Has anyone else had this happen? Dealership said $600 to repair.
  2. Feb 7, 2021 at 11:34 AM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    How big of a fuse did you replace the blown one with? Have you done any other mods that may have messed with the wiring?
    Taco_Coma likes this.
  3. Feb 7, 2021 at 11:36 AM
    Noswar5
    Noswar5 [OP] Member
    Macedonia Ohio
    No other mods. 7.5 Amp fuse what blew....
  4. Feb 7, 2021 at 11:38 AM
    Noswar5
    Noswar5 [OP] Member
    Macedonia Ohio
    19.95 led light package from Amazon.
  5. Feb 7, 2021 at 11:42 AM
    Clearwater Bill
    Billy
    Largo Florida
    There have been other reports of similar around here. Several times IIRC.
    Not sure always with the same lights as you used though, but with LEDs in general.
    With the gee-whizz electronics in these trucks Amazon-ese type parts sometimes create Kung Poo.
    Noswar5[QUOTED][OP], Chew and eggs like this.
  6. Feb 7, 2021 at 11:48 AM
    crbr
    crbr Well-Known Member
    east TN
    18 Sport / 93 Mastercraft Prostar 190
    My bet (on a positive note) is the short was self-inflicted. Rule number 1...disconnect the negative cable from the battery. I put in the bulbs (kit) with no issues, point being is the install is fairly straight forward. No inside information for success aside from the obvious.
    Best on the resolve.
  7. Feb 7, 2021 at 11:52 AM
    Noswar5
    Noswar5 [OP] Member
    Macedonia Ohio
    Thanks
    Appreciated
  8. Feb 7, 2021 at 11:54 AM
    ssd2k2
    Keith
    Minnesota
    I have some Amazon LED lights in my map and dome lights with no issues. I would guess is you accidentally turned it on while changing the bulbs and shorted something.
    Noswar5[OP] likes this.
  9. Feb 7, 2021 at 11:56 AM
    Noswar5
    Noswar5 [OP] Member
    Macedonia Ohio
    Never thought I would have to disconnect the negative cable just to change a map bulb from standard to LED. Learn something new everyday.
    davidstacoma likes this.
  10. Feb 7, 2021 at 11:59 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    From what I’ve read on similar failures here on TW you likely smoked a circuit board trace in the overhead console. If you or someone you know is electronically inclined you could take it down and inspect to see if you find the cause and repair it.
    Even with the dome light switches off 12V is still present in the dome light socket and as suggested above I always recommend removal of the negative battery cable or pulling the dome light fuse when replacing the bulb.
    You’re not the first this has happened to. Good luck and sorry to hear that happened.
    Edit: @caribe makaira I know your familiar with this issue, any advice for the OP?
    Noswar5[QUOTED][OP] likes this.
  11. Feb 7, 2021 at 11:59 AM
    Noswar5
    Noswar5 [OP] Member
    Macedonia Ohio
    May have. Thanks you ssd2k2
  12. Feb 7, 2021 at 12:01 PM
    Noswar5
    Noswar5 [OP] Member
    Macedonia Ohio
    Thank you so much davidstacoma. That is great to know and I will do that from now on.
    You are correct that is what the dealership said. I had no idea how to get my hand on one except thru the dealership. This is my first Tacoma and I have been waiting 30 years to get one.
  13. Feb 7, 2021 at 12:02 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Did u install backwards ?
  14. Feb 7, 2021 at 12:06 PM
    Noswar5
    Noswar5 [OP] Member
    Macedonia Ohio
    I do not think so
