Led lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TOYOTA junkie, May 8, 2019.
  1. May 8, 2019 at 2:21 PM
    TOYOTA junkie
    TOYOTA junkie [OP] New Member
    Tacoma
    Alot
    I swapped out taillights and plan on headlights also I have the dreaded hyper flashing going on and want to know if anyone has found a DTRL compatible flasher relay I have been on diode dynamics site and had no luck really would like to avoid resistors any advice would be appreciated
  2. May 8, 2019 at 2:24 PM
    Jon'sTaco4x4
    Jon'sTaco4x4 Pavement Princess
    Jonathan
    2019 Cement Tacoma 4x4 Off Road
    Radflo 2.5” Lift C4 Front & Rear Bumper OME Heavy Duty Pack Retrax Bed Cover UpTop Overland BedRack UpTop Overland Roof Rack Flowmaster Exhaust w/ TRD “CAI” Method 305 Some other cool stuff
    I did full swap with LED in my headlights and taillights and ran into the same problem and could not find anything to resolve it. You can still run everything LED just not the turn signals. That is what I do and in my opinion it is better than not running LED at all.
  3. May 8, 2019 at 2:36 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    There is no flasher or flasher relay on the 3rd gens. The turn signals are controlled by the "combination meter". If you're going to use LED turn signals, you either have hyper flash or add load resistors to mimic incandescent bulbs. There are LEDs available that have built in load resistors, but the selection is limited.
    Jon'sTaco4x4 and nartmot like this.
