LED Map Lights-Need Help
Discussion in 'Lighting' started by OxyGuy, Jan 14, 2012.
  1. Jan 14, 2012 at 7:06 AM
    OxyGuy
    OxyGuy [OP] Well-Known Member
    Conway, SC
    2007 PreRunner
    I got some LED map light bulbs. How do I remove the standard bulbs without a trip to the ER for stitches? I can't get a good grip on them and I'm afraid I will squeeze too hard and they will break. How do you guys do it?
  2. Jan 14, 2012 at 7:08 AM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    You could just take your overhead out and push the bulbs from their base IIRC.
  3. Jan 14, 2012 at 7:10 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    they are not that hard to do bro. I have changed mine a few times without breakage.. I to was worried they would break
  4. Jan 14, 2012 at 10:55 AM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    you can def push from the top if you remove your overhead console, but I just did it with pliers, i was worried bout it breaking too, but it didn't, and if it did, it wouldnt be in ur fingers
  5. Jan 14, 2012 at 10:58 AM
    SalmonTaco
    SalmonTaco Well-Known Member
    Andrew
    Naches
    08 Silver TRD Sport
    Brute Force bumpers, Bilstein 5100s & 885s, TRD Beadlocks, Yokohama Geolandar MT, SnugTop MVP Shell, Tuffy Bed Box, Console Vault, Fogs anytime, ImMrYo mirror bracket, Wet Okoles, aFe Pro Dry S, PowerStop Z36 pads & drilled/slotted rotors, more shit I can't remember
    Wrap the bulb with a bit of 2" painters tape, pinch the excess into a little "tail" and yank it out. Worked great for me.
  6. Jan 14, 2012 at 12:15 PM
    OxyGuy
    Conway, SC
    2007 PreRunner
    Thanks for the advice, guys. I got them out. They were pretty stubborn and fit into the socket really tight. I have a roll of the double sided tape to fasten on moldings and emblems. I cut a small strip of the tape and stuck it to the bulbs and it was sticky enough to get a good hold and pull them right out. Got the LED's in and all's well. I have a Honda CRV with LED's inside and have gotten used to them.
