LED Non Switch Back?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ruggybuggy, Jun 11, 2016.
  1. Jun 11, 2016 at 2:24 PM
    Ruggybuggy
    Ruggybuggy [OP] Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    I want to use LED's for my DRL, turn and marker on the front of my '12 Tacoma. There is talk that if you use the switch back (white/yellow) bulbs you have to cut the wire under the dash to disable the DRL or you will blow fuses. If I installed non switch back LED could I run these without issue? Basically looking for a brighter LED DRL without the heat of the 3157 bulbs.
  2. Jun 11, 2016 at 9:49 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
  3. Jun 12, 2016 at 10:54 AM
    Drinknmolson
    Drinknmolson Well-Known Member
    Wheat Ridge, CO
    10 DCSB sport
    Yes you can, you'll need load resistors to prevent fast blink. I ran em for the same reason and will again once i get new resistors.
  4. Jun 12, 2016 at 11:04 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Which ones did you buy? Also if you already have the LED factory tail lights do you still need the load resistors?
    Thks
  5. Jun 12, 2016 at 11:17 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    The link refers to switch back LED in amber/white which requires disabling the DRL. I'm just looking for amber LED'S that work the same as the incandescent bulbs.
  6. Jun 12, 2016 at 1:25 PM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    I have white/Amber ones and Amber only ones. Neither will pop fuses and whoever told you to disable Dtrls so they don't blow fuses means they were trying to sell you something not wired correctly for your truck.
    scottalot likes this.
  7. Jun 12, 2016 at 1:55 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Ive read a few threads on here that if you run the DRLs with the LED CK3157 it will blow fuses unless you disable your DRL buy cutting a wire under the dash that enables the DRL. So what amber/white bulbs are you running with your DRLS's that don't give you an issue?
  8. Jun 12, 2016 at 3:22 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I saw the video of the DLR white/amber and that's what im looking for if no modifications need to be made. Price and shipping time please? 55649
  9. Jun 12, 2016 at 3:44 PM
    csjumper2003
    Savannah, GA
    Amber only a bulbs and resisters. White/ambers u keep Dtrls they are just pull power elsewhere on the white/ambers. That's what the mod does. That is why I don't like the directions out and about because someone will say something and it isn't true.
  10. Jun 12, 2016 at 3:44 PM
    csjumper2003
    Savannah, GA
    Why white/ambers Unmodded work too, just a little different. These are all my own bulbs and yes none of these will give you that issue at all.
    Pm me if interested in any of these options and I'll send you a quite and explain further.
  11. Jun 12, 2016 at 3:56 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Understand. PM sent.
  12. Jun 12, 2016 at 5:21 PM
    KCCOtx
    KCCOtx Active Member
    Andrew
    tx Panhandle
    2014 4 dr off road edition.
    Steel plate tailgate Tonno cover Rails Led's all around (responder lights)
    I have a question for you gentlemen. Couple years ago I installed the switchback DTRL'S on my truck from csjumper2003. They still work great... but I noticed a year or so ago... they are always on now no matter what. What would have caused this? They didn't when I initially installed them.
  13. Jun 12, 2016 at 6:51 PM
    csjumper2003
    Savannah, GA
    If you did the mod then they have always been like that. You might not of noticed though. Anyways send me a pm and I can show you how you can turn them off if you want. But unless you installed them without the mod and did the mod later they had to be on all the time. That is how the mod works.
    KCCOtx likes this.
  14. Jun 12, 2016 at 8:47 PM
    KCCOtx
    Andrew
    tx Panhandle
    Gotcha, sorry for my ignorance.... never noticed until then. Just making sure I didn't screw something up. Thanks sir!
  15. Jun 12, 2016 at 9:19 PM
    csjumper2003
    Savannah, GA
    It's cool man. It happens all the time. Lol. Let me know if we need to outfit any other applications.
