LED plug n plays...
Discussion in '1st Gen. Tacomas (1995-2004)' started by anguseg, Oct 28, 2023.
  1. Oct 28, 2023 at 10:19 PM
    anguseg
    anguseg [OP] Well-Known Member
    Evan
    '04 Tacoma TRD 4 Door.
    Stock as can be. 2nd owner, mild rust from Illinois owner. Frame is solid and plan on just getting a toolbox for the bed, black steel wheels and some 31x10.5R15
    Wad curious if anyone ran these specific bulb. Thnks s bunch
    Termitor Fahren 2023 Upgraded H4/9003/HB2 LED Bulb, 30000LM 800% Ultra Brightness, 6500K Cool White, Wireless 1:1 Halogen Size, Canbus Ready, Plug and Play, Pack of 2 https://a.co/d/7hJSEHO
  2. Oct 28, 2023 at 10:25 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
  3. Oct 28, 2023 at 11:38 PM
    02hilux
    Planet: EARTH
    Do it right or I'll use my light bar to blind you in return.
  4. Oct 29, 2023 at 8:05 AM
    tacoman2001$
    tacoman2001$ Well-Known Member
    The way the high beam circuit works they don't pull enough current to turn the high beam light on in the cluster.
  5. Oct 29, 2023 at 9:04 AM
    anguseg
    Evan
    And you know this from experience?
    I m not trying to be a d!ck lol. I genuinely want to know before I buy them.
    Just a good old boy looking for a good ol set of plug n play LED
  6. Oct 29, 2023 at 9:09 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check out the link in post number 2. Just because they appear brighter and have a cool looking blue/white light doesn't mean they're an upgrade. What they're doing is scattering light up into the sky and blinding oncoming drivers.
    anguseg[OP] and 02hilux like this.
  7. Oct 29, 2023 at 10:01 AM
    anguseg
    Evan
    So honestly would I be better off buying some bada$$ halogens?
    Right now I'm running the Philip's RacingVision 150%
  8. Oct 29, 2023 at 10:06 AM
    anguseg
    Evan
    I've ran all sorts of LED in my old wife's stocking housings. Yesh they may be brighter....butthr scatter isn't worth it. Because Ive been on the other end of the lights driving lol
    Those Ostrams seemed pretty popular huh? Those are the brand I pulled out before throwing in the Philip's Racing Vision 150%
  9. Oct 29, 2023 at 10:44 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Read the thread posted above. Better quality halogen bulbs are only part of the equation. They are limited by the power available to them through the factory harness. The harness upgrade routes power straight from the battery to the back of each headlight, essentially bypassing the fuse box. The idea is that by combining the harness upgrade and good quality bulbs you'll see a substantial increase in output while retaining the optics of the factory headlight housing - meaning the light shines down the road instead of up into the trees
  10. Oct 29, 2023 at 2:16 PM
    tacoman2001$
    Yes I bought cheap Chineseum for shits and giggles. They're pretty bright beak pattern isn't too bad. The high beam indicator no longer works though. High beams still work. My advice would be to get some leds from a good brand like Phillips or Sylvania.
  11. Oct 29, 2023 at 7:24 PM
    anguseg
    Evan
    So I may be better off with the powerful Halogen.?
  12. Oct 30, 2023 at 7:31 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Unless you want to replace the housings. I did the wiring upgrade as laid out in the link in the second post and it was worth the money. Definitely suggest the upgrade.
