LED Pod GB -Closed-
Discussion in 'Closed Group Buys' started by Iggy, Oct 7, 2015.
  1. Oct 18, 2015 at 7:25 PM
    #161
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Here's what the standard mount looks like:
    and here's an idea of what the flush mount looks like (not my photo):
  2. Oct 18, 2015 at 9:00 PM
    #162
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    Cool...im wondering if the regular mount adjustable? Does it tilt up and down?
  3. Oct 18, 2015 at 9:01 PM
    #163
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Says in the first post, it rotates 360 degrees. So, no. It does not tilt up or down.
  4. Oct 18, 2015 at 9:24 PM
    #164
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If it is like other pods in that size, it will also tilt up and down a little in the vertical plane to allow adjustment of the height of the beam after mounting.
  5. Oct 18, 2015 at 9:29 PM
    #165
    WheelInTheSky
    G
    Jackson Hole
    Strange, but I could have sworn the 1st post used to explain this. Maybe it was eited out? Oh, well I've quoted an explanation from the OP:
    I'm guessing there wont be tilt.. No way to know until we all get our hands on them!
  6. Oct 18, 2015 at 10:13 PM
    #166
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    Ok add me for a pair of spot/regular mount please
  7. Oct 19, 2015 at 7:21 AM
    #167
    Phototaker
    Phototaker Well-Known Member
    Karl
    2015 Tacoma TRD LB
    I am good with Regular mount. now to find a bracket to mount them to that is rock solid..
    thanks for the G Buy.
  8. Oct 19, 2015 at 9:22 AM
    #168
    Iggy
    Northern CA
    Check out the build
    It does tilt like the post below. You have 360 degree of adjustment on the horizontal plain and some degree on the vertical plain.
  9. Oct 19, 2015 at 9:23 AM
    #169
    Iggy
    Northern CA
    Check out the build
    OK guys, I'm almost done setting up a cart so we can start placing orders! I have flat rate shipping down and this way make sure I get exactly what you want.
    Stand by
  10. Oct 19, 2015 at 1:06 PM
    #170
    Iggy
    Northern CA
    Check out the build
    Ok guys! We are active, so let's wrap this up!
    1. Go to cart.iggycorp.com under "Group Buys"
    2. Select what you'd like to get i.e. lights and covers
    3. Check out!
    I'll handle the rest and keep you all updated via this thread.
    1. @thebaker (2xFlood)(2xAmber)
    2. @VolcomTacoma (2xFlood)
    3. @VolcomTacoma (2xFlood)
    4. @530Taco (2xFlood)
    5. @SlipperyTaco (2xFlood)(2 xAmber)
    6. @rob1208 (2xFlood)
    7. @delesseria (2xFlood)
    8. @roguetrader (2xFlood)
    9. @TheFang (2xSpot)
    10. @Wack (2xFlood)
    11. @Wack (2xSpot)
    12. @drknsurfur (2xFlood)
    13. @ancr (2xFlood)
    14. @seijiishii (2xFlood)
    15. @Sicyota04 (2xFlood)(Flush)
    16. @DirtyTerp (2xSpot)
    17. @Fifthwind (2xFlood)(2xSolid Black)
    18. @Fifthwind (2xFlood)(Flush)
    19. @bbersanti (2xFlood)
    20. @WheelInTheSky (2xFlood)(2xClear)
    21. @WheelInTheSky (2xFlood)
    22. @ricantaco (2xFlood)(Flush)
    23. @toolmandoo (2xFlood)
    24. @Vanguard (2xSpot)
    25. @Tyson (2xFlood)(Flush)
    26. @TheWringer (2xSpot)(2xAmber)
    27. @TheWringer (2xSpot)
    28. @Phototaker (2xSpot)(2xClear)
    29. @madsand (2xSpot) (2xSolid White)
    30. @NLMOOmar (2xFlood)(Flush)(2xAmber)
    rob1208 likes this.
  11. Oct 19, 2015 at 1:14 PM
    #171
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    just placed my order. thanks @IGGY!
  12. Oct 19, 2015 at 1:20 PM
    #172
    Iggy
    Northern CA
    Check out the build
  13. Oct 19, 2015 at 1:21 PM
    #173
    Iggy
    Northern CA
    Check out the build
    Also, those that want local shipping, please put local shipping in the Notes. When you pickup I'll refund you the shipping.
  14. Oct 19, 2015 at 1:24 PM
    #174
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    Done
    Iggy[OP] likes this.
  15. Oct 19, 2015 at 1:31 PM
    #175
    WheelInTheSky
    G
    Jackson Hole
    Order placed, Thank you.
  16. Oct 19, 2015 at 1:32 PM
    #176
    Wack
    Wack Well-Known Member
    G
    Phoenix, Az.
    2015 TRD 4x4
    Order placed, Thanks Iggy.
  17. Oct 19, 2015 at 2:06 PM
    #177
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Any chance I can just pay in cash in person? I have cash in hand but not in the bank at the moment lol! Silly mortgage and 5 month old :(
  18. Oct 19, 2015 at 2:42 PM
    #178
    TheWringer
    TheWringer Active Member
    West Michigan
    '15 TRD Off-Road Access
    Bilstein 5100s, OME 885, LR UCAs, BFG KO2, AO Rims, Auto-dimming infinity edge mirror w/ compass and HomeLink, 30" Bi-Color LED light bar in lower valence, Raptor grille mod, Blacked out emblems, Fog light anytime mod, Rear Diff breather relocated to bed cubby, Front windows tinted 20%, Blacked out grille, Hi-Lift bed mount, LED interior lights, LED reverse lights, LED license plate lights, TRS LED fog lights, Wet Okole TRD Off Road seat covers, NFAB Bed-mount light rack, 4x 6" KC ProSport HID, 2x 6" rear LED pods, CrimeStopper Remote Start.
    Posting this on here because I know you'll probably get this 100x... when I put QTY 2 on your website I will be getting a total of 4 lights, correct?
  19. Oct 19, 2015 at 2:45 PM
    #179
    delesseria
    delesseria Active Member
    Tom
    Olympia
    14 TRD Off-Road Blue Ribbon
    ProEFX Heated Towing Mirrors, TRD cat-back exhaust, Snugtop Sport Hi-Liner, Hellwig EZ-990 Helper Springs, IGGYCORP LED pods
    Thanks Iggy.
  20. Oct 19, 2015 at 3:01 PM
    #180
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Ordered.
    Thanks Iggy.
    Had to chuckle at Iggycorp, can't wait to read the company slogan.
