LED Pod GB -Closed-
Discussion in 'Closed Group Buys' started by Iggy, Oct 7, 2015.
  1. Oct 7, 2015 at 9:44 AM
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    CLOSED Ends 10/23/15 at Midnight
    Go to cart.iggycorp.com under "Group Buys" to place your order.
    GB Details:
    $95 for a pair of PODs. Available in 4D SPOT or FLOOD/DIFFUSED. Regular or Flush Mount. Includes wiring harness.
    $6 for each cover in blue, green, solid white, solid black, red, clear or amber.
    $13.50 for USPS shipping.
    We need 10 pairs to get this going and if we hit 20 pairs the price will be $90 per pair.
    POD Specs:
    . Operating Voltage: 10-30V DC
    . Waterproof: IP 67
    . 4 x 5w high intensity OSRAM LEDs
    . Lumens: 2150
    . 20W Draw
    . Color Temperature: 6000K
    . Body Material: Diecast aluminum housing
    . Lens material: PMMA
    . Mounting Bracket: Stainless Steel
    . Opitonal Beam: spot beam,flood beam
    . 30000 hours above life time
    . Size: 80mm*75mm*82mm
    . Certificates: CE, RoHs, IP67
    These will also come with molded DT connectors just like all my other lights. So getting these running is only a matter of hooking up the wire harness to the battery and running the switch to the cab.
    Here are pics from my manufacturer:
    Optional Covers (Price pending, Black is also available)
    Thanks!
    1. @thebaker (2xFlood)(2xAmber)PAID
    2. @VolcomTacoma (2xFlood)(2xAmber)PAID
    3. @VolcomTacoma (2xFlood)(2xAmber)PAID
    4. @530Taco (2xFlood)
    5. @SlipperyTaco (2xFlood)(2 xAmber)PAID
    6. @rob1208 (2xFlood)PAID
    7. @delesseria (2xFlood)PAID
    8. @roguetrader (2xFlood)PAID
    9. @TheFang (2xSpot)PAID
    10. @Wack (2xFlood)PAID
    11. @Wack (2xSpot)PAID
    12. @drknsurfur (2xFlood)OUT
    13. @ancr (2xFlood)PAID
    14. @seijiishii (2xFlood)PAID
    15. @Sicyota04 (2xFlood)(Flush)
    16. @DirtyTerp (2xSpot)OUT
    17. @Fifthwind (2xFlood)(2xSolid Black)PAID
    18. @Fifthwind (2xFlood)(Flush)PAID
    19. @bbersanti (2xFlood)PAID
    20. @WheelInTheSky (2xFlood)(2xClear)PAID
    21. @WheelInTheSky (2xFlood)PAID
    22. @ricantaco (2xFlood)(Flush)PAID
    23. @toolmandoo (2xFlood)PAID
    24. @Vanguard (2xSpot)
    25. @Tyson (2xFlood)(Flush)
    26. @TheWringer (2xSpot)(2xAmber)OUT
    27. @TheWringer (2xSpot)OUT
    28. @Phototaker (2xSpot)(2xClear)PAID
    29. @madsand (2xSpot) (2xSolid White)PAID
    30. @NLMOOmar (2xFlood)(Flush)(2xAmber)PAID
    31. @Tacomatwo (2xFlood)(Flush)PAID
    32. @Delta00 (2xFlood)PAID
  2. Oct 7, 2015 at 9:47 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Whats the lumen output?
  3. Oct 7, 2015 at 9:48 AM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    How easy are these to mount? I have a pelfrey hybrid with tabs for lights.
  4. Oct 7, 2015 at 9:53 AM
    BamaToy1997
    Bill
    Navarre, FL
    I would like more specs on the lights to consider committing. Lumens, amp draw, etc.
  5. Oct 7, 2015 at 10:43 AM
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    we can get this diffused correct?
  6. Oct 7, 2015 at 10:45 AM
    thebaker
    Byron
    NorCal
    Should be easy. I'm running pods in my all pro bumper on the light tabs and they were easy to install. I'm hoping to get a difussed set of pods from this group buy to put in my bumper and move my old pods back to my ditch lights.
    Iggy[OP] likes this.
  7. Oct 7, 2015 at 10:47 AM
    06toyoboy
    06toyoboy Well-Known Member
    Whos the manufacturer
  8. Oct 7, 2015 at 12:09 PM
    Iggy
    Northern CA
    Check out the build
    I'm working on getting all final specs. What I know is:
    4 x 5W OSRAM OSLON led chip
    Lumen output is between 1800-2200 (Confirming)
    IP-67
    20W ~2A
    I'll get final numbers tonight, there's about a 12hr delay in getting solid info.
    These mount similarly to the Dually's
    Yes of course! Diffused/Flood are pictured in the second photo. You can mix and match too.
    These are built to my specs in China. They are not generic ordered from stock.
    thebaker[QUOTED] likes this.
  9. Oct 7, 2015 at 12:14 PM
    Iggy
    Northern CA
    Check out the build
    Keep the questions coming guys!
    @VolcomTacoma and @530Taco have seen my lights in person and I'm sure can chime in on the quality.
  10. Oct 7, 2015 at 12:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What are the physical dimensions of the housing?
    Any pics of the mounting system?
  11. Oct 7, 2015 at 12:28 PM
    VolcomTacoma
    Jeff
    NorCal
    Oh hell yea. I own a pair of the big 9" round ones and the quality is pretty damn high.
    @IGGY, quick question. Is there flood AND Diffused? or just diffused floods lol. If there is Both, I'd like one set of each, otherwise I'll just take 2 pairs! Local pick up :D
    thebaker likes this.
  12. Oct 7, 2015 at 1:39 PM
    530Taco
    530Taco Gone fishin'
    Adam
    Old Hangtown, CA
    '21 DCSB OR MT Cement
    Lovin my 30" hyperspot!
    I've been wanting some cubes for ditch brackets, can't decide if I should get spots for more left to right in the turns, or diffussed to help the headlights out... would diffused throw alot of glare onto the hood?
  13. Oct 7, 2015 at 1:47 PM
    VolcomTacoma
    Jeff
    NorCal
    I'd go diffused, that will light up front way more, where stuff can be hidden. Or do both :D
    Edit: Go with floods on the front, I thought they were the same...if you ahve a choice for front end, put floods on to really light everything up around you, while your spot gives you distance. Diffused is good for rear lights as it won't blind everyone
    530Taco and thebaker like this.
  14. Oct 7, 2015 at 5:55 PM
    Iggy
    Northern CA
    Check out the build
    It's one or the other. I'll see if I can get some made with the bottom diffused and the top spot. Those would be sick!
  15. Oct 7, 2015 at 6:24 PM
    VolcomTacoma
    Jeff
    NorCal
    No thanks :). I'll take a set of the diffused for rear dust lights, and a set of floods for the front :). When are you closing this? PM the details and we can meet up when you get lights :D
  16. Oct 7, 2015 at 7:15 PM
    Iggy
    Northern CA
    Check out the build
    I'm getting all the details together now may a week or two?
  17. Oct 7, 2015 at 7:21 PM
    VolcomTacoma
    Jeff
    NorCal
  18. Oct 7, 2015 at 7:25 PM
    VolcomTacoma
    Jeff
    NorCal
  19. Oct 7, 2015 at 7:31 PM
    wsurunner
    wsurunner Well-Known Member
    2015 Pyrite Mica DCSB
    Might be interested, pending dimensions. Considering sticking these behind the stock grille; any examples of that on TW?
  20. Oct 7, 2015 at 7:32 PM
    XCDave
    XCDave Well-Known Member
    David
    2015 TRD 4X4 long bed dbl cab
    None at this time.
    With no light bar where would I mount these ? No bull bar ect.
    I have a OEM roof rack is about it
