Led pod snow issues
Discussion in 'Lighting' started by Gnarman, Feb 23, 2018.
  1. Feb 23, 2018 at 3:51 PM
    Gnarman
    Gnarman [OP] Well-Known Member
    Southwest
    2016 dbcb trd off road quicksand lb
    ARB Shell, BP51, 255/85/16 ST MAXX, SCS Ray 10 Matte Bronze, Caliraised led 32 inch/side shooter/amber pods, floor mats, start x remote start, auxbeam 8 gang switch panel, diode dynamics hid lows, Australian Shepherd
    Hi everyone I need some suggestions, I have the Cali raised Amber LED fog lights and they are constantly getting covered in snow I tried to use Rain-X plastic I can't use WD40 because it will eat away at the polycarbonate anyone have suggestions on how to keep this away from the light or anything to make sure that snow doesn't touch the lights or stick to them? I am almost to the point where I may have to get rid of them.
    ChadsPride likes this.
  2. Feb 23, 2018 at 5:04 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This is a common problem with LEDs. OEM LED applications will have a heated lens to prevent this from occurring. OEM halogens heat the lens from the filament. The flat conclaved face of a LED pod certainly makes things worse. I’d imagine you’d have better results with the bubbled curved surface of the Morimotos. But if you live somewhere that it snows regularly, aftermarket LEDs are not going to be a good lighting source due to icing.
  3. Feb 23, 2018 at 6:50 PM
    Gnarman
    Southwest
    Agreed @CaliRaisedLed you have any suggestions here? Not sure what to do and I don't want to get rid of them.
  4. Feb 23, 2018 at 6:54 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  5. Feb 23, 2018 at 7:01 PM
    Cooktop86
    Cooktop86 Well-Known Member
    Jeff
    Hatfield, Pa
    2017 Tacoma TRD sport MGM
  6. Feb 25, 2018 at 6:03 AM
    Gnarman
    Southwest
  7. Feb 27, 2018 at 6:42 AM
    Gnarman
    Southwest
  8. Feb 27, 2018 at 6:51 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This isn’t an issue with their product, it is a drawback of using an aftermarket LED in cold weather vs an OEM heated LED.
    Same thing happens when you put LEDs in your headlights. They freeze over and you cannot see anything.
    stealthmode and paranoid56 like this.
  9. Feb 27, 2018 at 7:22 AM
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
    Unfortunately there is not much you can do.
    crashnburn80 and paranoid56 like this.
  10. Feb 27, 2018 at 11:44 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Try Pam (your wifes kitchen spray).
  11. Feb 27, 2018 at 4:22 PM
    lynyrd3
    Bill
    East Central Upstate NY
    Im glad I saw this post ! Was thinking about the Baja Squadron in the OEM fog hole .Lots of snow here . Will be looking at the Morimotos now !
  12. Feb 27, 2018 at 4:28 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I have the Morimotos and they're not that great (for melting snow) either.
  13. Feb 27, 2018 at 4:30 PM
    lynyrd3
    Bill
    Hmmm ,delema :(
  14. Feb 27, 2018 at 5:52 PM
    Gnarman
    Southwest
    Quick update so I am going to use a couple different products I have something called snow jet which is used as a polymer spray for snow blowers I am also going to try to use Pam as some have suggested here. We are going to be getting a large Storm soon and I will report back my findings shortly.
    Also I want to give props out to at @CaliRaisedLed for responding to this thread and owning up to a small feature miss, I work in sales and I appreciate when someone can let me know that there may not be a fantastic solution for my issue. Mad props to Cali raised I will still support and purchase their products.
    03 NIGHT TACO and crashnburn80 like this.
  15. Feb 27, 2018 at 5:58 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    crashnburn80 likes this.
  16. Feb 27, 2018 at 6:02 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The BD Pods also do not have cut offs for street use. They should be considered off road use only or in situations where high beams are acceptable.
    lynyrd3[QUOTED] likes this.
  17. Oct 19, 2018 at 3:21 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I know this is an older post, but icing is something I have always thought about as a challenge to LEDs for those in colder climates. However, there is a partial solution.
    Check out these prototypes from Rigid linked below. Using an amber lens filters out the short wavelength (blue) light, and the Rigid LEDs put out a lot of light, and a lot of short wavelength (blue) light at 7400k color temp. Light is energy, and since energy cannot be created or destroyed, when it is filtered out it is transferred to heat. Meaning as the amber lens filters out the blue light, the lens gets hot. It takes a while for the lens to warm up by doing this, maybe 30+ minutes, so it won't melt the snow off the lens from being parked, but when running it should prevent icing. I've had the 'white' Rigid pods and the lens does not get hot.
    This is the lens temp, not the body.
    You can read more info about these upcoming pods here:
    https://www.tacomaworld.com/threads...fog-light-review.554813/page-14#post-18889711
    Thunder chicken likes this.
  18. Oct 22, 2018 at 6:20 AM
    Gnarman
    Southwest
    Thank you this is awesome!
    crashnburn80[QUOTED] likes this.
  19. Oct 22, 2018 at 7:22 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Lights are to be released in December with the same pricing as the white SAE fog pods.
    Technique likes this.
