Led Pods as Rock Lights??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kgarrett11, Mar 6, 2017.
  1. Mar 6, 2017 at 1:50 PM
    kgarrett11
    kgarrett11 [OP] Master Yoda
    Garrett
    CA desert
    2015 DCLB
    So my Led strips I stuck under the door worked great as rock lights for awhile. But after several trips, washes, etc they have died on me. Thinking about putting a couple Amazon pods under the truck. Anyone do this? Where the best place to mount? Pics? Advice? Thanks!
    ChadsPride likes this.
  2. Mar 7, 2017 at 6:55 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I think it'd be cool! Just get some cheap ones and reseal them before mounting them. To mount them, you'll have to get creative. If you don't have bolt on sliders, there are plenty of holes you could use.
  3. Mar 9, 2017 at 10:55 AM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Ya the mounting is where Im getting hung up. Was hoping someone already found the sweet spot and done this before
  4. Mar 9, 2017 at 10:58 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Id worry about ripping them off.
    1. @Iggy sells some nice rock lights.
    2. You can also use KC Hilite Cyclones, theyre flat aand can be bolted down. They come in different color too.
    Iggy likes this.
  5. Mar 9, 2017 at 10:59 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Word.
    Rock lights are small and flat. Pods are usually 3" squares.. that's a lot of sacrifice in ground clearance/tire articulation no matter where they're mounted underneath.
  6. Mar 9, 2017 at 11:13 AM
    ramonortiz55
    Ramon
    Texas
    stock
    you can buy the lights by themselves, for like $30 each. and run your own harness and switch
  7. Mar 9, 2017 at 11:13 AM
    T4RFTMFW
  8. Mar 9, 2017 at 11:14 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'd think that pods that are mounted in the frame rails would be just fine as far as being tucked up enough. There are plenty of lower things to get ripped off.
  9. Mar 9, 2017 at 11:14 AM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    The KC kit is badass, expensive tho... Cant find iggys yet. Was hoping not to spend a whole lot on this, which is why I originally thought of the cheap pods but like you guys mentioned, I dont know how/where to SAFELY mount them up and out of the way
    ManBeast likes this.
  10. Mar 9, 2017 at 11:15 AM
    T4RFTMFW
    Repost.
  11. Mar 9, 2017 at 11:16 AM
    ramonortiz55
    Ramon
    Texas
    stock
    I swear that messed with my head lol
  12. Mar 9, 2017 at 11:17 AM
    T4RFTMFW
    I wanna mess with your head.
    kgarrett11[OP] likes this.
  13. Mar 9, 2017 at 11:18 AM
    Pigpen
    Dan
    Northwest Montana
    Just zip tie some flashlights under there
  14. Mar 9, 2017 at 11:18 AM
    T4RFTMFW
  15. Mar 9, 2017 at 11:19 AM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Ya I think that would be my best bet because I already have the wiring done still and those ones are alot larger than Iggys it seems...
    Do either of you have rock lights yourselves?
  16. Mar 9, 2017 at 11:19 AM
    ramonortiz55
    Ramon
    Texas
    stock
    ive never had anyone speak to me with such romance.
  17. Mar 9, 2017 at 11:20 AM
    ramonortiz55
    Ramon
    Texas
    stock
    I cant find the whisper emoji.. lol
  18. Mar 9, 2017 at 11:20 AM
    T4RFTMFW
    I don't, because I previously had a Prerunner.
    But Iggy lives 20 minutes from me, and is a good friend. Can vouch for him, his character, and my Tacoma had all @Iggy lights on it, as do a lot of our local members trucks.
    Iggy likes this.
  19. Mar 9, 2017 at 11:20 AM
    T4RFTMFW
    Mi chula hermosa.
  20. Mar 9, 2017 at 11:21 AM
    ramonortiz55
    Ramon
    Texas
    stock
    :rolleyes::gossip:
