LED Pods
Discussion in '3rd Gen. Tacomas (2016-2023)' started by loosegrip, Dec 2, 2016.
  1. Dec 2, 2016 at 11:23 AM
    loosegrip
    loosegrip [OP] Member
    Canada
    2016 Tacoma TRD ACOR MT
    I've been doing a bit of research and would like to find some pod mounts for the front end of the truck (bumper/grill) but have come up empty handed. Does anyone know of any fabricators who produce mounts for LED pods rather than for only light bars? Appreciate any insights!
  2. Dec 2, 2016 at 11:52 AM
    Cold_Toad
    Cold_Toad Well-Known Member
  3. Dec 2, 2016 at 1:13 PM
    loosegrip
    Canada
    Thanks for the input @Cold_Toad! I failed to mention I've upgraded the fogs to morimoto already. I think at this stage the best solution may be to use Apex bar mounts (or the like) then fabricate a cross bar to facilitate the use of pods, namely the BD SII in the lower grill area. That could work!
  4. Dec 2, 2016 at 1:15 PM
    ryanl2425
    ryanl2425 Doesn't work..Hit with hammer...Then hit harder
    Truckee, CA
    2015 MGM Tacoma DCSB Prerunner
    Cali Raised led
    loosegrip[OP] likes this.
  5. Dec 2, 2016 at 1:53 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Could you not buy the 30" light bar bracket for behind grille and mount 1 pod on each side instead of light bar? The brackets are very sturdy!
  6. Dec 2, 2016 at 2:18 PM
    loosegrip
    Canada
    I was thinking of that as a solution actually, which they appear to be rigid enough although therein lies the problem of mounting since the holes are on the sides. I suppose an L bracket would quickly resolve that, but I would like to mount them inboard of the sides likely in the second bay of the lower grill which could cause some bouncing issues. Depending on where you would want them I think both ideas would work!
  7. Dec 2, 2016 at 2:55 PM
    Broccoli
    Airdrie Alberta
    Why cant the pods be sideways? They should have full motion to swivel tilt etc.
  8. Dec 2, 2016 at 3:58 PM
    loosegrip
    Canada
    Good point, you're right. I have been looking at the Baja Designs S2's which may not work placed sideways and I'm not aware of any others that would fit in the lower grill that are within the height of that space (2") if turned sideways.
  9. Dec 2, 2016 at 4:13 PM
    Broccoli
    Airdrie Alberta
    Rigid duallys, baja s2 , any 4led pod should measure approx 2x2.
  10. Dec 2, 2016 at 5:54 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    I bet if you bought some lights a shop could make up some brackets for you
  11. Dec 3, 2016 at 7:08 AM
    loosegrip
    Canada
    Thanks for both the suggestions, I'll have a look at the Rigid's. Getting some brackets made or possibly just taking it on myself is a definite consideration, they're certainly not overly complex.
