Led projector headlights
Discussion in '1st Gen. Tacomas (1995-2004)' started by Everardo97, Jun 27, 2020.
  1. Jun 27, 2020 at 12:29 PM
    Everardo97
    Everardo97 [OP] Active Member
    Woodland CA
    1997 3.4L 4wd (automatic)
    I’m looking to get some new headlights and I found an led projector with a halo that I like but idk if I should go with that. It would be nice because I can make the halos my turn signal since I just installed a steel bumper and have the original signals just zip tied on. Let me know what you think or if you think there’s a better way to go, thanks. https://www.carid.com/1997-toyota-t...ctangular-halo-led-headlights-2650008714.html
  2. Jun 27, 2020 at 8:11 PM
    joe25rs
    joe25rs Well-Known Member
    Joe
    Mrr’land
    2004 Black TRD
  3. Jun 27, 2020 at 9:29 PM
    Taco1997
    Taco1997 Well-Known Member
    SoCal
    2001 Tacoma prerunner, 2024 Tacoma TRD Offroad
    @LSC15
    Or BXBuilt are the two options I know of for projectors.
  4. Jun 27, 2020 at 9:37 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Turn signal mod:
    Just cut off the mount from the turn signal housing and do a little trimming and shaping with a dremel, then epoxy them in place. Some people will cut the shape to mount the bulb right into the housing, but this seemed a little easier and less likely to leak.
  5. Jun 28, 2020 at 12:16 PM
    Everardo97
    Woodland CA
  6. Jun 28, 2020 at 12:19 PM
    Everardo97
    Woodland CA
    For my turn signal I think I’m going with this idea thanks! When I first thought of using the side lights for my signals I didn’t think about being able to keep them doing both signals and parking lights.
  7. Jun 28, 2020 at 2:23 PM
    joe25rs
    Joe
    Mrr’land
    2004 Black TRD
    Unless you desperately need lights, keep an eye out for a sale...
  8. Jun 29, 2020 at 8:20 AM
    jbrandt
    Justin
    I can't take credit for the idea, but it's worked well for me. My CBI bumper came with LEDs mounted in the bumper, so I just used a couple quick splices and now I have both the stock ones and the LEDs.
  9. Jul 19, 2020 at 1:43 AM
    Everardo97
    Woodland CA
  10. Jul 19, 2020 at 11:33 AM
    Taco1997
    SoCal
    I don’t think they’ll because fit the side markers for a 97 look a little different than 01-04 but hopefully someone else can chime in and give you a definite answer
  11. Jul 19, 2020 at 12:07 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    I put a different year side markers in my truck. I had to make a new bracket to be able to screw it down. Not sure what year they were from but it took minor modification.
    Taco1997 likes this.
