LED replacement bulbs for 2019 Taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bokshi, May 1, 2025.
  1. May 1, 2025 at 6:46 AM
    bokshi
    bokshi [OP] Active Member
    Maryland
    2019 TRD Sport
    I replaced the factory bulbs in my 2019 Taco with LED bulbs High and low, but it seems like the ones you get on Amazon are cheap quality and or time lasting (maybe the ones I chose). Any recommendation for where you bought your LED bulbs would be appreciated.
    Also, I drive a lot in the dark (Early Morning) and am looking for the max brightness so I look for the highest luminous number that I can get that is compatible for my track.
    Thanks !!
  2. May 1, 2025 at 6:49 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Halogen housings aren't meant to spread the light from LED's. You are better off buying a nice halogen bulb or swapping light housings to OEM LED housings.
    If you are dead set on installing an LED bulb, VLED's is a damn good place to buy bulbs.
    scouterjan, musicisevil and Chew like this.
  3. May 1, 2025 at 6:51 AM
    Clearwater Bill
    Billy
    Largo Florida
    ^^^ this.
    Dozens of threads around here on the topic.
  4. May 1, 2025 at 6:55 AM
    airforceb2cc
    Don
    KCMO
    Veet-88, Barsoom, musicisevil and 2 others like this.
  5. May 1, 2025 at 6:55 AM
    TacoWave
    TacoWave Well-Known Member
    Adam
    2017 PRO MT
    Checkout vleds.com
    bokshi[OP] likes this.
  6. May 1, 2025 at 6:58 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  7. May 1, 2025 at 7:43 AM
    tacoma warrior
    tacoma warrior Well-Known Member
    2020 Tacoma SR5 silver
  8. May 1, 2025 at 7:59 AM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Install the same Halogen H9 bulb your highbeam takes in your low beams, in place of the H11. The colored insert inside the wiring harness plug can be removed with a pair of needlenose pliers, allowing the H11 plug to fit the H9 bulb plug-base.
    The best H11/H9 bulb crashnburn80 has tested were the Gen 3 (not gen 4) morimoto LED bulbs, but while they offered the best focus, they were about equivalent to a decent standard output H11 bulb. The H9 offers about a 70% intensity bump, which translates into a significant increase in low beam distance reach.
    Most of the other LED retrofit bulbs crash has tested performed worse than the standard H11 that was installed at the factory, most also shifted the highest intensity zone down below the horizontal cut off, meaning distance vision was reduced while everything near the vehicle was illuminated too brightly, further reducing your ability to see things at a distance.
  9. May 1, 2025 at 8:11 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Basically, stop trying to shove LED replacement “bulbs” in a halogen housing.
  10. May 1, 2025 at 8:15 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    It’s another headlight thread. Is it Friday already?
    Do exactly what @Toy_Runner said….
  11. May 1, 2025 at 8:32 AM
    eurowner
    eurowner Duke Sky
    Scoty
    http://www.danielsternlighting.com/tech/bulbs/Hid/conversions/conversions.html
    H9 upgrade is excellent.
  12. May 1, 2025 at 8:40 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
  13. May 1, 2025 at 8:41 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    did the mods purge a a couple thousand of them? :D
  14. May 1, 2025 at 1:58 PM
    danielgonzzz
    danielgonzzz Well-Known Member
    Daniel
    2019 Tacoma TRD Sport 4x4
    Stawk as FUCK!
    I’ve been running Hikari Ultra bulbs since my truck was new in 2019 and still love them! Never had issues in all the years of hard off-roading. Still on the same set!!
    VaToy likes this.
  15. May 2, 2025 at 1:03 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    We could shift this into a "blinker fluid upgrade" thread ...
    OZ TRD and t0p_d0g[QUOTED] like this.
  16. May 2, 2025 at 5:49 PM
    Mobeus102
    Mobeus102 Member
    Vic
    2002 crew cab
    3 inch old man ,magnaflow cat back, Sony double din,ultra wheels,new grille with raptor lights ,custom rear bumper,etc.
    I tried the h9 low beam mod and was not that impressed then I read reviews on the led bulbs from Vleds pricey yup but the result was exactly what I was looking for.
    VaToy likes this.
