led replacement bulbs for climate controls 2003 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by jrsmith2tn, Feb 6, 2011.
  1. Feb 6, 2011 at 1:43 PM
    jrsmith2tn
    jrsmith2tn [OP] Member
    john
    tennessee
    2003 tacoma dbl cab
    I need to replace climate control bulbs in my 2003 tacoma with led type bulbs but cannot find any references as to which bulbs to use. The current bulbs are like the NeoWedge series LED's, they are not the normal wedge bulbs.
  2. Feb 6, 2011 at 1:56 PM
    bobby15
    bobby15 Well-Known Member
    SoCal
    09 DC LB 4x4 magnetic grey tacoma
    might be able to find bulb sizes on sylvania.com
  3. Feb 6, 2011 at 2:05 PM
    bobby15
    SoCal
  4. Feb 6, 2011 at 3:40 PM
    giscott
    giscott Well-Known Member
    Scott
    Austin
    2003 TRD SR5 PreRunner DC Revtek 3" Lift,
  5. Feb 6, 2011 at 6:23 PM
    bivey
    bivey Well-Known Member
    Does anyone know how many are behind the controls? Also how many are behind the gauge cluster?
  6. Feb 6, 2011 at 6:34 PM
    giscott
    Scott
    Austin
    I think there are 4 behind the gauge cluster. Somebody correct me if I'm wrong.
  7. Feb 6, 2011 at 6:38 PM
    TRDguy
    TRDguy Cruisen GA
    Marietta ,GA
    2010 PreRunner DC SR5 TRD Sport
    K & N air filter, antenna X 13in., window tint, vent visors, bug guard, floor mats, door sill protectors, tonno-pro tri-fold tonneau cover, pop n lock tailgate lock, Truck Champ chrome Nerf Bars, LED lights in cupholder mod, tailgate hose clamp mod, stainless bull bar, 1 inch leveling kit, rear under the bumper LED's, Halo headlights.
    I say get the climate control interface off and see what you need and then try and find them. Check Radio Shack, eBay, or just google the numbers on the bulbs if you can read them. You might find the exact bulb or better yet, and LED replacement. Good luck, probably won't be super easy! GO Packers!
  8. Feb 6, 2011 at 9:42 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    3 behind the controls and 4 behind the cluster!
    mbledvinka likes this.
  9. Feb 7, 2011 at 4:11 AM
    jrsmith2tn
    john
    tennessee
    2003 tacoma dbl cab
    Thanks to all who have responded, still don't know which bulbs fit. I am going to try sending one of mine to the a vendor and see if they can match it with a compatible LED bulb. I will post the results here when I get it.
  10. Feb 7, 2011 at 5:42 AM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    For the temp controls, I bought some at Radio Shack that were 12v and small & soldered them into the leads.
    That fixed my problem - sorry I don't have the item # though.
    It was tricky getting the case apart but it was doable, with a small screwdriver and some prying.
  11. Feb 7, 2011 at 2:31 PM
    jrsmith2tn
    john
    tennessee
    2003 tacoma dbl cab
    I still want to use replacement bulbs without special alterations. There should be some that fit. The image above is the type required I just don't know which size.:D
  12. Feb 7, 2011 at 2:48 PM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    For the dash led's use 194's and you will need 4 of them. Make sure to get the leds that have 5 led's and that use a wide angle like these.
    http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=/specs/WLED-x5.htm
    For the A/C controls it requires #74 bulbs it takes 2 for the controls and those bulbs can be single led's like these.
    http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=/specs/74-x.html
    If you follow what I said you will have results like mine(I used blue ones).
    If you have any questions just let me know I'm here to help.
  13. Feb 9, 2011 at 5:40 PM
    bivey
    Does anyone know what size the map lights are?
  14. Feb 9, 2011 at 9:16 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    why does everyone want LED? I hate when the lights inside are too bright when I'm driving at night, and they give you shitty hot spots, I want to go with blue, but definitely NOT LED.
  15. Feb 10, 2011 at 4:01 PM
    bivey
    Nevermind same as the dome light.
  16. Feb 10, 2011 at 5:07 PM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Rab I had blue leds in my truck and they were beautiful with no hotspots etc.. well worth it imo. The ones id be worried about is on the climate controls but that's just due to design, instruments are fine
  17. Feb 10, 2011 at 5:42 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
  18. Feb 10, 2011 at 5:55 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    well, how about I send you my cluster, and you make it blue!
  19. Feb 10, 2011 at 7:25 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Haha id be doing the easy part so.. sure why not! But seriously just get some 5x wide angle highpowered leds and you'll be good I sold my blues to my friend, they were sexy but I thought wtf everyone has blue so I got red and now my truck looks like an attack helicopter at night lol
  20. Feb 11, 2011 at 1:37 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    haha nice, how did you deal with the orange on the back of the cluster?
