LED reverse lights flickering!
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, Feb 12, 2017.
  1. Feb 12, 2017 at 9:40 PM
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    i installed some 18watt LED aux lights and they flicker just like my LED 1156s did. Is the wattage too low? What's the problem here? The stock 1156 wattage is 26 watts so the LED wattage being too high isn't the issue.
    http://youtu.be/mQ8OfwlqIco
    EDIT:
    I'm going to put the solution in here for anyone searching. It was a bad backup light switch, Part # 84210-52050. I will probably remove my relay once I install the new switch, no sense in having a wire going from my tail light all the way to the battery if I can help it.
    EDIT: putting new switch in fixed problem. Removed relay and still no more flickering. Yay!
  2. Feb 13, 2017 at 10:04 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Fuck it, I'm going to throw a resistor in line with each light and I'll report back.
  3. Feb 13, 2017 at 10:06 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  4. Feb 13, 2017 at 10:18 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  5. Feb 14, 2017 at 10:27 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Actually screw it, I'm just going to add a relay. Didn't want to have to run a wire for the whole length of the truck but i don't have a choice
    -_-
  6. Feb 15, 2017 at 9:20 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Relay fixed The flickering, as I thought it would. I guess that means even though the LEDs don't draw that much power, the reverse light wiring is not exactly 'clean' power
  7. Feb 16, 2017 at 6:56 AM
    Tacoma_2000
    Tacoma_2000 Member
    Brian
    2000 base 2wd
    Or the ground you supplied using the relay is making a better connection.
  8. Feb 16, 2017 at 7:59 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Using the same ground as the aux lights (mounting bolt from a hole I made in the bumper). Didn't change the ground at all. FWIW my 1156 leds in the reverse of the tail lights flickered the same way. I think the reverse light power wire is not very good.
  9. Feb 16, 2017 at 10:47 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
  10. Feb 16, 2017 at 11:07 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yeah, that's what I was hoping to do. I mean, they don't draw that much power. There shouldn't need to be a relay used. But I did the same, tapped into the reverse power wire, and still got the flicker, the same flicker that was happening with LEDs installed in the tail's reverse socket. Maybe my reverse light wire is messed up somewhere, but not sure how or where it would be messed up. Either way, glad the relay fixed it at least.
  11. Feb 16, 2017 at 11:39 AM
    jammer
    Ben
    Bentonville, AR
    Well, I will say this, they light it up in the back now. I can never complain again about not being able to see out the back. I almost went with the 30W, but I'm glad I didn't now.
  12. Feb 16, 2017 at 12:12 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Did you wire them inline or parallel with the factory reverse bulbs?
  13. Feb 16, 2017 at 12:18 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Each light had its own ground and its own power, which was drawn from the reverse light power wire on the tail harness
  14. Feb 16, 2017 at 12:36 PM
    tony2018
    tony2018 Well-Known Member
    Tap into another source and if it still flickers than the led's are the issue.
  15. Feb 16, 2017 at 12:55 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Works fine with the relay. See previous posts.
  16. Feb 20, 2017 at 1:35 AM
    Wulf
    rock raisin
    I just added a pair of 18w LED pods. I tapped the power for each of the existing reverse bulbs and used the existing ground point under the bed. I don't have any flickering. :anonymous:
  17. Feb 20, 2017 at 6:29 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    :mad: :mad: :mad: lol
  18. Feb 20, 2017 at 9:21 AM
    tony2018
    Corrosion must play a part somewhere.....
  19. Feb 20, 2017 at 9:25 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Maybe. At this point it works great with a relay, so I'm not going to worry about it too much.
    tony2018[QUOTED] likes this.
  20. Feb 20, 2017 at 9:31 AM
    tony2018
    Gotcha, I would've done the same too.
