Led Running boards courtesy light wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nightstriker, Apr 6, 2020.
  1. Apr 6, 2020 at 11:22 PM
    Nightstriker
    Nightstriker [OP] Well-Known Member
    2013 Tacoma Prerunner
    And how is the switch wired to a 3 prong switch?
  2. Apr 6, 2020 at 11:28 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Circuit means complete loop. Ground is where all of the current flowing in the circuit ends up. Ultimately at the battery negative terminal. A relay separates the current that flows from the battery through your lights, through the high current side of the relay and back to ground from the current that flows from the battery through the coil side of the relay and your switch through the ecu and back to ground. Instead of 4A plus the dome light current getting grounded through the ecu you only have ~.1A to trigger the relay plus the dome light current.
    Muddinfun likes this.
  3. Apr 6, 2020 at 11:30 PM
    Muddinfun
    Muddinfun Well-Known Member
    Look at the schematic. It’s the same as you have, except the middle terminal is connected to the relay instead of the LED strips.
  4. Apr 6, 2020 at 11:32 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    What part of the paper plate don’t you understand? Seems pretty clear to me.
  5. Apr 6, 2020 at 11:34 PM
    Nightstriker
    Because my idea was to use this switch so that I can turn it on even if the dome light ground is not giving power. So my idea was the first position will turn on the LEDs as long as I need then without the done light ground because it will have it's own ground then position 2 will be the off position, position 3 is the automatic position whereby it uses the dome light ground for power.
  6. Apr 6, 2020 at 11:36 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Exactly what you need, 3 terminals and 3 positions. Try not to confuse the middle terminal with the middle position.
  7. Apr 6, 2020 at 11:36 PM
    Nightstriker
    So the switch will have 2 grounds right? Ok from the dome light (blue wire) and one from the truck's frame right? And a wire from the relay.
  8. Apr 6, 2020 at 11:37 PM
    Nightstriker
    So will get the effect I want?
  9. Apr 6, 2020 at 11:38 PM
    Muddinfun
    Yeah, so there’s your 3 terminals.
    Ground
    Relay-86
    ECU-blue wire
  10. Apr 6, 2020 at 11:39 PM
    Muddinfun
    Yes.
  11. Apr 6, 2020 at 11:40 PM
    Nightstriker
    Hey, for the bed lights and the rear single led strip can I add a switch so that I can turn them off if I don't need them? Like just a simple 2 prong switch in the middle of the live wire...
  12. Apr 6, 2020 at 11:40 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Yup, all you are doing is providing ground for your switch current. The relay then connects your leds to ground and you get BLING.
  13. Apr 6, 2020 at 11:40 PM
    Nightstriker
    Wow thats cool.
  14. Apr 6, 2020 at 11:46 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Muddinfun did all the heavy lifting, thank him. I’m just a fucking idiot that can’t stay away. As far as independent switching goes, yes, you could then interrupt the led wires with switches.
  15. Apr 6, 2020 at 11:47 PM
    #35
    Muddinfun
    Yes, a simple switch in the wires to whichever strips you want to not light.
  16. Apr 6, 2020 at 11:51 PM
    #36
    Nightstriker
    Ok Muddinfin, thank you very much for your help, I really appreciate it.
    bagleboy and Muddinfun[QUOTED] like this.
  17. Apr 7, 2020 at 5:37 AM
    #37
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    I've seen a lot of wiring diagrams before, but this is the first one I have seen literally served up on a silver platter (alright paper, close enough). That's awesome!
    Muddinfun[QUOTED] likes this.
  18. Apr 7, 2020 at 6:52 AM
    #38
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I’m excited to see the post “fucked up my body ecu none of my shit works anymore help!”
  19. Apr 9, 2020 at 11:44 PM
    #39
    caribe makaira
    Caribbean, Puerto Rico
    OP, if you enjoy relay chatter that's what you'll get if you tie into the blue wire for dimming to off...
  20. Apr 28, 2022 at 3:43 PM
    #40
    Tah-koh-mah
    Tah-koh-mah Well-Known Member
    2012 Tacoma TRD-Off Road
    Sorry to revive an old thread, but in your diagram, if I do not use a switch, do I leave pin 86 empty? Or must I wire something to it? Thanks!
