LED running lights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kencraw, Jul 2, 2012.
  1. Jul 2, 2012 at 6:37 PM
    kencraw
    kencraw [OP] Member
    Ken
    Roseville, CA
    2012 double-cab SR5 2.7L
    I bought the following replacement LED daytime running lights for my 2012 Tacoma:
    http://www.amazon.com/gp/product/B0042FRUN4/ref=oh_details_o03_s00_i01
    The "Putco Amber 3157 Type 360-Degree High Intensity LED Premium Replacement Bulb" (for those who don't want to click on the link)
    When I put them in, it blew the 15A turn/hazard fuse, which really surprised me.
    Anyone have that happen? Did I just get a defective pair? Has anyone successfully used them? Or what about a different brand of LED bulbs in the daytime running lights?
    Also, I didn't realize (I'm not sure why, it's obvious) that the daytime running lights are also the turn signal/hazard lights. I've heard that sometimes LED replacements don't use enough current to trigger the toggling. Does anyone know if that's an issue with the Tacoma and the daytime running lights?
    Any advice/experience would be appreciated.
  2. Jul 2, 2012 at 8:19 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Got the wrong bulb Theres some threads in here explaining how to check what bulbs you need.Some has positive and negative on same side and the other has pos and neg on oposite sides .something like that Try do a search.Some good info.
  3. Jul 3, 2012 at 5:12 PM
    dlg636
    dlg636 Active Member
    Darrin
    Honolulu, Hawaii
    4x4 Tacoma w/all the goodies
    DR front coils and rear shocks, deaver springs, load leveling airbags, k&n intake, JBA hedders and exhaust,Unichip power chip, URD short shifter, onboard air compressor, upgraded power inverter (1000W put in stock inverters location) budbuilt traction bar, warn transformer winch mount and warn winch, HID headlights and foglights, full LED bulb conversion, LED bed lights, full stereo system with GPS and they all roll on 16x8 black steel rock crusher and 285/75R16 BFG KM2's.
    you need to do them one at a time cause they have a positive and negative side. one or maybe both could be backwards. same thing happened to me when i changed mines. went through a couple fuses doing mines but once i got them the right way they worked perfect. goodluck
  4. Jul 3, 2012 at 5:48 PM
    Large
    Large Red
    Pm Chris (csjumper2003) he will point you in the right direction.
  5. Jul 3, 2012 at 5:51 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    You need non polerised, ive blewn fuses using polerised before.
