Led scanner
Discussion in 'Lighting' started by Ray1749, Mar 22, 2013.
  1. Mar 22, 2013 at 6:43 AM
    Ray1749
    Ray1749 [OP] Ray J
    Ray
    NY
    16 tacoma sport blazing blue
    3" lift tint tailgate inserts LED bed lights LED brake light strip Bed cover
    Does any body know how to hook up scanner. Where do I get Ignition ground when eng is off. HELP!!!
  2. Mar 22, 2013 at 12:22 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Please clarify your question and give us your model and year.
  3. Mar 22, 2013 at 1:06 PM
    Ray1749
    Ray1749 [OP] Ray J
    Ray
    NY
    Trying to hook up a Led scanner. there are 3 wires red black & yellow. Don't know where to hook them up so the scanner works when truck is off. I have a 2013 DCLB 3" lift,tinted windows,chrome handles, mirrors,Leds under truck, piaa 110/135 extreme white,ventvisors,hooddeflector,inside leds,Led brakelight strip.
  4. Mar 22, 2013 at 6:11 PM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    La Mesa
    2014 SSM Trd Off Road 4x4 Auto
    If your wanting it to work when the key is out then your going to have to tie the red and yellow together and the black im assumimg is ground can be run to any number of grounds. A lot of people use the screw behind the kick panel or the one that takes ground from the battery. Again as yellow and red I would assume the yellow is constant and the red is accessory. So normally if you were wanting it to run only with key you would go to an ignition fuse under the dash, yellow constant to the battery and ground just about anywhere. So you tie the yellow and red together send them to battery and hook up ground. It should work without key in then.
  5. Mar 22, 2013 at 6:16 PM
    csjumper2003
    La Mesa
    To reiderate. The yellow is to keep the pattern or function its on when not powered on. Red power when key is in and ground is ground
  6. Mar 22, 2013 at 6:25 PM
    Ray1749
    Ray1749 [OP] Ray J
    Ray
    NY
    Thanks will try in morning.
  7. Mar 23, 2013 at 5:54 AM
    Ray1749
    Ray1749 [OP] Ray J
    Ray
    NY
    Hi Chris
    Thanks for your help. I hooked up red to bat. black to ground and now the yellow and red made it stay on all the time. I looked for a fuse that was not hot when truck was off it was # 6 in fuse box I tapped it and the scanner worked. When I started truck the scanner went off. Now it works fine. Thanks for your Idea on where to look. Ray
