LED side markers up front 2007 base model
Discussion in 'Lighting' started by 07TacoRidah, Mar 26, 2010.
  1. Mar 26, 2010 at 9:57 AM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    Okay so I'm a bit pissed to see that someone else got his LED's to work up front for the side markers. Granted he got them from a better place than I did still, lol. I was reading a little and found that apparently the LED's won't work but then saw the person with his on and with a pic showing them on AND WORKING!!!! :mad::mad: I think it's a blue dc w/blue LED's sides, yes that one. :p
    I don't want to change the color really, I just want it brighter, so I got some LED's and they don't light up ANYWHERE near the person with the blue LED's. Do they really work up front or not? I REALLY want to get them to work. I finally decided on what color to use other than red on my taco, which is orange (going to be coloring the calipers HOK/Chevy Orange, i think that's the name), so I will be putting this on almost all the parts on my truck (engine, brakes, rims (if I can ever get them)).
    SO if you have the sides working, how did you get them to work and where did you get you LED's from? I'm guessing my LED's that I have suck major balls, ergo why they aren't working.
  2. Mar 26, 2010 at 4:00 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    I have amber led from pep boys in mine. not as bright as the purple one you are talking about cause blue/purple appear brighter but yes they do work. If yours dont light up turn the led 180 degrees as they only work in one position
  3. Mar 26, 2010 at 4:03 PM
    07TacoRidah
    damn I didn't know that, is it better to test them when it's a bit darker to know which way is better?
  4. Mar 26, 2010 at 4:05 PM
    t_e
    Erik
    miami,fl
    u can do it during the day. just put in the led and test it before you plug it back into the headlight so you can see if they work cause its a pain to get them out.
  5. Mar 26, 2010 at 10:49 PM
    07TacoRidah
    well put them in again, not so bright at all. I took them off and put in the regular bulbs I had in my top console lights instead. :( I have to find a better bulb.
  6. Mar 27, 2010 at 10:05 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Did you see a picture or in person? Also, do you have the BHLM and painted the side marker reflector?
  7. Mar 27, 2010 at 12:05 PM
    07TacoRidah
    picture, it was in a search I did for LED's. The picture was from a member on here, he used blue to match his dc. Haven't done the BHLM yet, trying to find the candy yellow tint (so far just yellow tint, looks dull for me). I think it's the LED that I used though. I looked up some other ones and they have about 4/5 little LED's in one bulb, on mine, there's this little dinky one.
  8. Mar 27, 2010 at 12:07 PM
    07TacoRidah
    these are the ones I have, well they look close to them, just not as bright at all :(
  9. Mar 27, 2010 at 12:08 PM
    07TacoRidah
    would these be better? or is it just lacking the power for them?
  10. Mar 27, 2010 at 12:19 PM
    07TacoRidah
  11. Mar 27, 2010 at 3:24 PM
    t_e
    Erik
    miami,fl
    amber is not nearly as bright looking as blue or white.
  12. Mar 27, 2010 at 4:39 PM
    07TacoRidah
    but the ones in the first pic should light up like the ones I have one right now. They don't, it looks like it's not getting enough power.
  13. Mar 27, 2010 at 5:35 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    The picture will make it look brighter...
  14. Mar 30, 2010 at 9:25 PM
    07TacoRidah
    which ones should I get so that they are bright, not like a small dot.
  15. Mar 30, 2010 at 9:46 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
