LED signal lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toms2014, Nov 10, 2016.
  1. Nov 10, 2016 at 4:01 PM
    toms2014
    toms2014 [OP] New Member
    Tommy
    4-dr Tacoma Prerunner
    LED lights
    I just purchased a '14 Tacoma & desire to install LED signal lights. Rather than installing resistors into each light harness, I've heard that there are special signal flashers for the vehicle that do the resisting within themselves to stop the quick signal flashing when using LED bulbs. Does anyone know where these can be obtained & also, is the signal flasher located in the fuse box?
  2. Nov 11, 2016 at 6:41 AM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
  3. Nov 11, 2016 at 6:49 AM
    Pork Chopper
    Dallas, TX
    07 DC 4x4
    There should be a write up on how to remove the lower dash panel but basically
    Pull up carefully on the door sill/scuff plate
    Remove the dead pedal
    Remove the kick panel and this will give you access to the lower dash
    Unbolt the fuse block and relay is on the back
  4. Nov 11, 2016 at 6:51 AM
    awfilms
    awfilms Well-Known Member
    06 Tacoma TRD 4x4
    ^^^^ what he said
  5. Nov 11, 2016 at 7:03 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    I dont believe they make an LED flasher that works on the 2012 plus but if there is one please let me know.
  6. Nov 11, 2016 at 7:35 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    I've read that too. :(
  7. Nov 11, 2016 at 10:47 AM
    weendoggy
    weendoggy Well-Known Member
    Aptos, CA
    2014 TRD ACOR 4x4
    Access Original Tonneau Cover; Toyota Side Tube Steps; Focal ISS690 front speakers; Clarion XC1410 mini amp; Gentex 453 rearview mirror with Homelink, Compass, Temp and Autodim; Prodigy P2 trailer brake controller, Heated Seats from www.cobraheat.com, BriteAss Fogs, Phillips Extreme LED H/L. Heated mirrors from @Up2NoGood. 5100 Bilstein all four corners.
    Will this work with switchback DRL/signal LED's as well?
