LED strip attachment
Discussion in 'Lighting' started by easler24, Feb 14, 2013.
  1. Feb 14, 2013 at 4:07 PM
    easler24
    easler24 [OP] Well-Known Member
    Josh
    Michigan
    Those of you who have installed some LED strips on the interior of your vehicles, how have you attached the strips to the plastic? I got a 5 meeter strip that I have ready to attach to certain parts of the interior, but the 3M tacky strip that I have on the back of the light strip is not going to stay on the plastic. Any ideas on how to attach so it will stay? Maybe some hot glue?
    If anyone has experience with that please respond.
    Thanks!
  2. Feb 14, 2013 at 4:12 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Have you tried the 3m? Any 3m double sided stuff I have ever used has pretty much stuck well on any kind of surface.
  3. Feb 14, 2013 at 4:19 PM
    easler24
    Josh
    Michigan
    I did try to attach the strip to the plastic. I had just a 6 inch strip and it didn't want to stick at all. It is very possible that I had some sort of Armorall or something on the dash, but either way, it didn't want anything to do with staying on there.
  4. Feb 14, 2013 at 5:49 PM
    Me Likey TRD
    Me Likey TRD Well-Known Member
    Stan
    Eastern Oregon
    2012 TRD Sport DCSB
    Toytec Ultimate w/Dakar leaf packs, Michilin 265/75/16 LTX AT2, FJ Trail Team replica wheels, Access Ltd bed cover, Katzkin leather, Brute Force rear bumper, Relentless Fab front bumper, Beefed sliders
    Ya, I had the same problem with double sided tape.
    I ended up using the tape, but put a dab of super glue on it so it would stay put.
    Sounds a bit crude, but I didn't use much and is holding just fine.
  5. Feb 15, 2013 at 5:20 AM
    easler24
    Josh
    Michigan
    I think I will try hot glue first before going with something as permanent as Super Glue. Hot glue might hold them in place. We will see!
    Anyone had luck with getting these to stay in place?
  6. Feb 15, 2013 at 7:18 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    I used double sided 3m tape from the auto parts store...put it on the plastic first and let it set for an hr or so...also clean the plastic first with rubbing alcohol
    The tape I used I believe is for trim...its not the thin kind that comes on the led strip. Mine have held up for 6 months
  7. Feb 15, 2013 at 7:20 AM
    skygear
    skygear                    
  8. Feb 15, 2013 at 7:27 AM
    RDtres
    RDtres Well-Known Member
    Albuquerque
    2012 Tacoma DC LB
    Use Isopropyl to clean the surface well. 3M has yet to fail me when applied to a properly prepped surface. Good luck
  9. Feb 15, 2013 at 7:52 AM
    steve103
    steve103 Well-Known Member
    steve
    santa cruz ca
    07 taco
    arb bumper,bilstein shocks,886 ome springs,ar mojove rims,2optima batteries,custom electrial.on board air,cb,14gal frontrunner water tank,frontrunner roofrack
    what he said.........
  10. Feb 15, 2013 at 10:28 AM
    easler24
    Josh
    Michigan
    Thanks guys. I appreciate the help.
  11. Feb 15, 2013 at 11:28 AM
    RedTacoDriver
    RedTacoDriver Out of my mind....be back later.
    Dale
    Portland, OR
    2012 Tacoma Regular Cab 2.7L
    BakFlipG2, Westin Nerf Bars, Harbor Freight Bed Jacks, Flame Devil Horns, vinyl raven emblems, intermittent wiper switch swapout More to come.
    And when applying it to cold surfaces hitting it with a hair dryer or heat gun to warm up the application is also a plus.
