LED Strip Lights as Turn Signals
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dirtboy2009, Dec 27, 2020.
  1. Dec 27, 2020 at 2:11 PM
    Dirtboy2009
    Dirtboy2009 [OP] Well-Known Member
    Scott
    2016 Taco SR5
    I installed two-color strip lights on the rockers of my truck yesterday. I hooked the white lights up to my dome lights, they work great.
    I temporarily connected one of the lights to my left turn signal as a test to see if I would have hyper-flash. It didn't. So I went ahead and connected both sides to their respective turn signals (spliced in behind the light socket) and turned the key to test them out. Both bulbs burned out! WTF?
    I think I tapped into the ground side of the light.
  2. Dec 27, 2020 at 2:24 PM
    caribe makaira
    Caribbean, Puerto Rico
  3. Dec 27, 2020 at 2:54 PM
    Dirtboy2009
    Scott
    2016 Taco SR5
    You're right. I'll get a photo tomorrow. Thanks.:thumbsup:
  4. Dec 27, 2020 at 3:03 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Sweet font
    Taco_Coma, Redeemed and Tacospike like this.
  5. Dec 27, 2020 at 3:17 PM
    Tacospike
    Two Trucks
    :rofl:
  6. Dec 28, 2020 at 8:10 AM
    Dirtboy2009
    Scott
    2016 Taco SR5
    Ok. Here are photos.
    Driver side first
  7. Dec 28, 2020 at 9:20 AM
    caribe makaira
    What can you show about the added LED's and their taps?
  8. Dec 28, 2020 at 2:47 PM
    Dirtboy2009
    Scott
    2016 Taco SR5
    The LED's are 70" strips and the hook up is pretty simple. The courtesy lights work.
  9. Dec 28, 2020 at 2:53 PM
    caribe makaira
    So the turn bulbs burned out when turn was selected and the Yellow LED's do not illuminate?
  10. Dec 28, 2020 at 3:17 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Did you blow a fuse?
  11. Dec 28, 2020 at 5:26 PM
    Dirtboy2009
    Scott
    2016 Taco SR5
    The yellow LEDs went I to hyper flash along with the rear turn signals.
  12. Dec 28, 2020 at 5:27 PM
    caribe makaira
    That is due to loosing the resistance of the halogen turn bulbs. (blown coil in lamp)
  13. Dec 28, 2020 at 5:28 PM
    Dirtboy2009
    Scott
    2016 Taco SR5
    No blown fuses. I disconnected the amber LEDs and replaced the blown bulbs and I'm back to normal operation. I did not connect the amber LEDs again.
  14. Dec 28, 2020 at 5:29 PM
    Dirtboy2009
    Scott
    2016 Taco SR5
    Understood.
    Still not sure why the front bulbs blew out though. Would be nice if I could find a wiring diagram.
  15. Dec 28, 2020 at 5:44 PM
    caribe makaira
    Your SR5 has the turns as DTRL as well. Maybe the circuit misbehaved while having an additional LED in the combo circuit.
    Test by trying a jumper wire to the rear turn signals for the added LED's instead.
    Dirtboy2009[OP] likes this.
  16. Dec 28, 2020 at 7:13 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Caribe knows all :) The wire you tapped is a combination of the DTRL and turn signal. I assume you just want the strip LEDs to act as turn signals, and not DTRL as well? Do you have a link to the strip lights? I am curious what is inside that holder on the ground wire.
  17. Dec 29, 2020 at 5:19 AM
    Dirtboy2009
    Scott
    2016 Taco SR5
    Thanks for the diagram. I'll give this a try.
  18. Dec 29, 2020 at 5:21 AM
    Dirtboy2009
    Scott
    2016 Taco SR5
    It's a fuse. First time I've seen a fuse on the ground of an LED strip.
  19. Dec 29, 2020 at 6:28 AM
    Puppypunter
    Johnny
    2019 Black SR
    Yeah, odd place for a fuse. If tapping the strips off the rear works, let us know :)
  20. Dec 29, 2020 at 7:59 AM
    caribe makaira
    Don't go by color of wire for positive & negative. Especially when instructions are written poorly.
    Color changing LED's are negatively switched for color selection.
