Led switch won’t turn off
Discussion in 'Lighting' started by Dans2131, Feb 8, 2020.
  1. Feb 8, 2020 at 3:01 PM
    Dans2131
    Dans2131 [OP] Active Member
    Daniel
    2020 white tacoma trd off-road 4x4
    Hey , so I have put an led bar with an after market switch , the switch had 2 lights I side one to indicate when the led bar is on and another one that turns on and off when the headlights turn on because it is tapped into the fuse box into panel fuse , the problem I am having is that the switch light stays on all the time indicating the led bar is on . The other light inside the switch works fine and turns on and off with my lights , any way to fix this so that the light only turns on when I click the switch and turn on the led bar ?
  2. Feb 9, 2020 at 6:53 AM
    Tacospike
    Two Trucks
    Is this a new install or old Install and just now having this issue?
    The switch itself might be bad.
  3. Feb 9, 2020 at 6:57 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Wait a minute and see if the switch turns off with the dome lights. I had a similar issue with one the switches I installed and after a minute it would switch off with all the other things.
  4. Feb 10, 2020 at 7:51 PM
    Dans2131
    Daniel
    This is a new install , my ditch lights are using the same switch and work fine and this switch seems to work fine because the light that should turn on with the head lights turns on and off with the head lights but the light that should turn on only when the switch is on is constantly on . I am thinking of disconecting it from the battery clicking the switch to the on pos putting power back on and hopefully when I click the switch off the light will turn off .
  5. Feb 10, 2020 at 10:07 PM
    YotaBum
    YotaBum Not So Well-Known Member
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Blacked Out-887-Dakars-LR UCA-FJ Trail Team wheels-285 BFG KO2
    Ran into this issue on a second switch I installed...
    This thread helped me on the first switch I installed - https://www.tacomaworld.com/threads/air-on-board-to-rigid.407987/#post-12094171
