LED Tail Light Bulbs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJake318, Nov 3, 2023.
  1. Nov 3, 2023 at 1:01 PM
    TacoJake318
    TacoJake318 [OP] Member
    Jake
    2016 Tacoma
    Hi all, I have a 2016 Taco and I’m wondering if I installed led bulbs for the rear blinkers and left the fronts incandescent, would I get hyperflash and need to wire in some resistors? Or because it’s coming on with incandescent fronts they’d be ok?
    I’d appreciate if anyone has tried this to let me know
  2. Nov 3, 2023 at 1:20 PM
    Okkine 2.0
    Okkine 2.0 Well-Known Member
    2022 TRD Sport, Lunar Rock
    I removed those annoying stickers on the sun visor.
    If the bulb is designed to fit into the existing socket, it'll already have all the required resistors built in.
  3. Nov 3, 2023 at 1:47 PM
    TacoJake318
    Jake
    2016 Tacoma
    I have sylvania led bulbs I have not had a chance to try yet. They don’t have built in resistors, I’ll see if they work.
  4. Nov 3, 2023 at 2:33 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    All I can relate is my experience with the Meso total tail stage 1 LED kit. My fronts were left as is. I had no hyperflash with the turn signals unless I put the truck in reverse at the same time. I replaced the Meso stuff with Form Lighting LED tail lights and that all went away because they have a built-in resistor. It really varies from truck to truck as to whether you'll need resistors or not.
    musicisevil likes this.
  5. Nov 3, 2023 at 3:10 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I tough Meso had this solution for hyperflashing ... https://mesocustoms.com/collections/exterior-lights/products/total-tail-load-resistors
    But maybe I misunderstood your post.
  6. Nov 3, 2023 at 3:45 PM
    wayne0
    wayne0 Well-Known Member
    You can't go wrong with VLED tails!!
  7. Nov 4, 2023 at 12:28 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I did the VLEDS with their resistors and no issues at all.
  8. Nov 4, 2023 at 3:37 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    They do, and I actually have those resistors but didn't install them because my lights only hyperflashed when in reverse with the turn signal on. Because this rarely happened I didn't bother with them. I just wanted to let the OP know that it really depends on each individual truck whether you will get hyperflash or not. The replacing with the Form Lighting tails wasn't due to the hyperflashing. I just preferred them to the OEM housings with the total tails. You're right, I probably wasn't clear LOL.
