LED Tail lights installed. NO BLINKERS WORK
Discussion in 'Lighting' started by 0Taco6, Apr 19, 2016.
  1. Apr 19, 2016 at 2:02 PM
    0Taco6
    0Taco6 [OP] Active Member
    Philip
    Central Florida
    2007 Tacoma Prerunner
    6inch Rough Country Fab tech control arms Bilstein 5100 ICI Front bumper 20in Rockstar II 35inch Cooper Discover stt pro
    I'm sure there is a thread on here about this. I couldn't find one. I installed full LED rear light fixtures in my gf's 2007 TRD Sport. Everything works but the blinkers. Running lights, brake lights. No flashers up front or rear or light on the dash. I heard you need to install resisters to trick the computer since LED puts out much less power. But i installed the stock lights back before anything else and the blinkers still don't work. The flasher module/relay was also replaced.
    I did check the horn/cruise fuze...the kit said it might blow that. PLEASE HELP!!
  2. Apr 19, 2016 at 2:19 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Not sure this is your issue or not, but as far as resistors go, you might want to just put in an electronic flasher. But I don't see why your stock lights didn't work after. Check th3 other fuses?
    0Taco6[OP] likes this.
  3. Apr 19, 2016 at 3:57 PM
    0Taco6
    Philip
    Central Florida
    Yeah it's very weird. The relay is good too. Resistors are needed for the LED. heck I even disconnected the battery thinking it might reset it. Still nothin
  4. Apr 24, 2016 at 10:45 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    using resistors is more of a bandaid, if you get the proper flasher then it will work like stock.
    Island Cruiser likes this.
  5. May 2, 2016 at 9:38 PM
    RexsTaco
    RexsTaco Well-Known Member
    Vincent
    San Antonio
    Maxtrac spindles Bilstein 5100 adjustable OME 885 coil JBA UCA's Custom leaf pack and Maxtrac extended shocks in the rear. 35x12.5 Atturo Trail blade M/T Moto Metal 18x12 -44 offset wheels.
    had this happen to ma a few days ago, check the fuse box under the hood for blinker. I don't remember which one it is, just check one by one and im sure you find that one that burnt out.
