led tail lights wont work on 1st gen tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mym Mars, Jan 27, 2014.
  1. Jan 27, 2014 at 9:51 PM
    Mym Mars
    Mym Mars [OP] Member
    Ruby
    Bigfork, Mt
    98 Taco 2.7 5spd 4x4 reg cab
    Mechanically stock, 21.5" led driving light, 4x 4" by 4" floodlights.
    im on this strange trip to replace all my lights with leds to reduce all draw on my taco, only remaining ones are the 2 bulbs in my ac contols, headlights, and my brake lights/tail lights, now, the led brake lights work (had to use a shotgun to push down the pedal so i could see em) but my tail lights/rear markerlights wont work. now the orig bulb is a dual filiment bulb featuring 2 contacts on the bottom and a bayonet socket that prevents turning the bastard around ( i understand that leds are pole specific) just before i go through the effort of mailing the things back, does anyone have any experiance with this and if so, is their anything im doing wrong, any resistance that i need to put in line, and if possible, a link to a plug and play bulb that you may have used to successfully do a upgrade to led
  2. Jan 27, 2014 at 9:56 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    More elaborate info on what you have ? I replaced all my stock bulbs with less and they work fine, another member replaced his entire brake light with some leds from ebay and they also worked fine
  3. Jan 28, 2014 at 12:03 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    just make sure the run/brake are 1157, the turns are 1156, and reverse are 921s
  4. Jan 28, 2014 at 7:44 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    where are you sourcing your bulbs from?
    you say brakelights/tail lights.
    is this brake driving turn reverse, talk to me goose.
    ill assume turn, you will have similar issues as you did on the front. however i have not personally found any bulbs, LED, dual filament, that one filliment is brighter then the other.
    finally, you used a shotgun to press brake pedal to confirm working? how country are you? why not drive an old beatup chevy? a brick would of been significantly safer....
  5. Jun 19, 2014 at 9:54 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    run/brake are 1157
    turns are 1156
    backup are 921
    3rd brake light are 194
    you read correct. red LED for red lense. the wavelength of the light will pass through the same color lense easier. incandescent just have more spread out light.
    I have gotten light from www.superbrightleds.com for my bike
    you could even find cheap ebay ones
  6. Jun 19, 2014 at 9:59 AM
    BamaToy1997
    Bill
    Navarre, FL
    OP, I didn't have any problems at all replacing all of my lights with LEDs. To save the time and hassle of resistors and such I bought Superbrightleds.com's LED flasher which is electronic, not load based so no hyperflash either. What LEDs are you installing? I think we all need more info here.
  7. Jun 20, 2014 at 3:42 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Maybe some resistors? When I changed out my rear turn signal bulbs in my 06' I had the hyper blink so I had to add an in-line resistor to get rid of it and it worked.
  8. Jun 23, 2014 at 9:49 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    https://www.superbrightleds.com/mor...f13gl-02-led-bulb-electronic-flasher/782/836/
    this plugs in behind the driver foot plastic piece fuse panel. Fog light mod uses a relay to close a circuit so you can use the dual filament.
    also this thread is 6 months old, doubt OP will respond.
