LED Tail Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DK'sTaco2023, Jan 20, 2023.
  1. Jan 28, 2024 at 10:22 AM
    VTi EG6
    VTi EG6 Well-Known Member
    TX
    2017 Taco TRD Sport
    Yes sir had them on for about a year now.
  2. Jan 28, 2024 at 10:23 AM
    VTi EG6
    TX
    2017 Taco TRD Sport
    Initially I had a brake override error that led me down a rabbit hole for 3 days…
    Long story short, one of my VLED’s on the right tail lamp was bad. I disconnected the plug and all my lights functioned we normal (including brakes).
    I didnt have spare VLED replacements so I just inserted my factory bulbs for now.
    Hopefully if anyone ever gets this alert. After checking all your fuses, Id go check your bulbs as well. (Disclaimer Im not too savy at all with electrical lol) I appreciate everyones posts through out the site to help me narrow it down.
    Glad it wasn't a trailer harness connector issue.
    I went ahead and ordered replacement pair of LED bulbs for the right side.
    HisDad[QUOTED] likes this.
  3. Jan 28, 2024 at 10:31 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I’m surprised that you had a failure, but I suppose they do happen. I actually don’t run the VLEDS red bulbs anymore because I like the appearance of the incandescents better in the sunlight. So I keep a pack of 10 bulbs under the seat in my truck just in case I ever need to change those. But glad you figured it out.
    HisDad likes this.
  4. Jan 28, 2024 at 10:50 AM
    VTi EG6
    TX
    2017 Taco TRD Sport
    If they end up being faulty again i’ll stick w the halogens and just use their amber/white reverse/amber turn signal lol.
    Just crazy how it all happened driving home after work one morning with that damn override alert.
  5. Apr 3, 2024 at 9:41 AM
    BLtheP
    Plano, TX
    I’ve never had any good luck with anything I’ve bought there. I know a lot of people like their stuff, so I try not to talk about it too much but I definitely had nothing but mediocre to poor experiences on every product I bought from them. I didn’t have bulbs fall out of sockets but I did experience alternator whine when bulbs were installed and on the brake bulbs they were too bright on low mode and not much brighter in high mode. That’s how Amazon bulbs are, DD shouldn’t be the same at their price. I use VLEDS with great results for bulbs and always use Rigid for anything pod type. Never had a failure.
    Nonamesleft4u[QUOTED] likes this.
  6. Apr 6, 2024 at 7:16 PM
    JohnnyRotten
    JohnnyRotten Member
    Diode Dynamics = Horrible company. How can a brand new bulb just fall right out? Somebody needs to be tarred and feathered then drawn and quartered. What a waste of money.
  7. Apr 6, 2024 at 7:31 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    I've had the MESO kit for over a year and my only complaint is there isn't a large enough difference between running lights and brake lights. Not certain if it's because the running lights are brighter than stock, brake lights are dimmer than stock or a combination of both.
    How are the VLEDs in that aspect?
  8. Apr 6, 2024 at 7:41 PM
    BLtheP
    Plano, TX
    Cheap LEDs usually are pretty bad about brightness differences, especially with low mode being too bright and high mode not much brighter. My opinion of the Meso was that the low mode was too bright, definitely brighter than incandescents. High mode was fine. Meso low mode was brighter than VLEDS for sure. High was about the same across the two. All the LEDs on high mode are about the same brightness as incandescents.
    I actually run incandescents in my conversion, not because I thought the VLEDS were bad but I just feel like the incandescents are easier to see when the sun is on them, probably due to being warm white instead of red. The LEDs being darker cherry red just don’t seem to shine through as much, especially on all-red lamps. But I’d definitely choose VLEDS over Meso when choosing LED.
  9. Apr 7, 2024 at 12:23 PM
    wayne0
    wayne0 Well-Known Member
    Just an FYI. Those incandescent lamps in your comparison photo are NOT Halogen.
    They are just stock incandescent lamps.
    If they work better for you, that's great.
