LED Tailgate Bar
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TrdTaco171991, Jul 29, 2018.
  1. Jul 29, 2018 at 3:44 AM
    TrdTaco171991
    TrdTaco171991 [OP] Well-Known Member
    Adam
    Upstate NY
    17' TRD Sport MT BRDCSB
    I am looking into purchasing an Led tailgate bar for my gen 3. Does anyone have any suggestions on which one is bright and has 5 functions. I see mixed reviews on the OPT-7 and Putco products.
    Any suggestions??
  2. Jul 29, 2018 at 3:55 AM
    Clearwater Bill
    Billy
    Largo Florida
    Is this one of those strips that goes under the gate, above the bumper?
    I've only seen those on domestics, not that that should functionally matter I guess. But they almost never seem to be working right.
    Curious what the 5 functions are. Running, brake, left turn, right turn and ??
  3. Jul 29, 2018 at 4:07 AM
    TrdTaco171991
    Adam
    Upstate NY
    Yes, they get mounted under the tailgate/above bumper. If I could find one that I know has good results I'd at least give it a try...the 5th function is reverse.
    J.B. likes this.
  4. Jul 29, 2018 at 4:47 AM
    TheyCallMeBruce84
    TheyCallMeBruce84 Well-Known Member
    NC
    2020 Tundra Limited CrewMax Barcelona Red
    I have a 48" Putco Blade and it is much brighter than the images on their website show. I put it on in early May and (6,000+ mi later) noticed last week that I have one LED segment that is out on the right turn signal. YMMV
    https://www.putco.com/blade-led-tailgate-light-bar
  5. Jul 29, 2018 at 4:53 AM
    TrdTaco171991
    Adam
    Upstate NY
    Damn man that sucks, are you going to try to get a new one through warranty? I was looking at that same led bar as well. You would think with a higher price tag it would last at least a year before going out...
    TheyCallMeBruce84 likes this.
  6. Jul 29, 2018 at 4:54 AM
    TheyCallMeBruce84
    NC
    I just noticed their 3 year warranty listed on the website...I will have to follow up on that.
  7. Jul 29, 2018 at 9:55 PM
    ToyoVL
    ToyoVL Well-Known Member
    I ordered the opt7 led bar and used the curt wiring harness 5 way so I crimped the reverse wire with a bullet connector and plug to this harness. Since the bar will cover the spare tire hold, I used 2 sided 3M dual lock tape
    SJ3551 to tape to the truck and the bar in case that I need to remove the LED bar.
    https://www.amazon.com/CURT-56584-Custom-Wiring-Harness/dp/B007EA6WQU
    https://www.amazon.com/Insulated-Bullet-Connectors-22-18Ga-100pcs/dp/B001HXFW8Y
    Rett72 likes this.
  8. Jul 30, 2018 at 3:16 AM
    necrodiety
    necrodiety Well-Known Member
    Orlando
    2018 Silver TRD Sport
    OV Tune, Bakflip F1, Redline hood struts, faux pro headlights and tails, Meso: bucket, map and dome lights, fuse cover.
    Do these not block the access hole for the spare?
  9. Jul 30, 2018 at 4:00 AM
    TrdTaco171991
    Adam
    Upstate NY
    What's your opinion so far on the OPT-7, any good??
  10. Jul 30, 2018 at 6:51 AM
    ToyoVL
    I just had it for 3 months. So far everything is still functional. I like the sequential signals. Reverse light is bright. The LED bar is about 1 inch long so it will cover the hole.
  11. Jul 30, 2018 at 6:58 AM
    TrdTaco171991
    Adam
    Upstate NY
    Thanks for the feedback! Do you have any pi s of it on your truck? I have not seen any pics on a Tacoma.
  12. Jul 30, 2018 at 7:36 AM
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    I think I did the same thing that you did, or vise versa. :thumbsup:
    I love my Opt-7 light bar. I have had other brand on previous vehicles and most seem to have points of failure after 1-2 years. The Opt-7 works like new, not a single led has failed.
    My only critical comment would be that the channel holding the lights is filled with silicone which does a great job of sealing it. They did not add any vinyl, plastic, or other hard or more durable protective cover. A hard cover my shed dirt faster/better but will also run a risk of breakage. Both clear plastic and vinyl would run risk of yellowing with sun exposure, so I don't know IF there is a better solution.
    Mine has had zero trouble. I have noticed that the exposed silicone does seem to hold a bit of dirt that must be hand washed. I found that when I wiped the bar with alcohol, a lot of soot looking stuff came off and the bar itself looked much clearer. The alcohol wipe was the simplest and fastest method I have found to date to completely clean it after a wash.
    My critic in no way diminishes it's value, just a suggestion for future improvement. I would definitely, get this one again if I had need for another arise.
  13. Jul 30, 2018 at 7:41 AM
    TrdTaco171991
    Adam
    Upstate NY
    Thanks for the input, I may just go with the opt-7 then. Do you remember which model you purchased?
  14. Jul 30, 2018 at 8:17 AM
    TC_Mic
    Amber sequential signals. I linked it. see product section below.
  15. Jul 30, 2018 at 8:21 AM
    BT17
    BT17 Well-Known Member
    B
    17 Tacoma TRDORDCSB 4x4 AT KDmax SLT/Reg
    a few...
  16. Jul 31, 2018 at 6:44 AM
    TrdTaco171991
    Adam
    Upstate NY
    Purchased the OPT-7 48" in red! Hopefully it works longer than a week! :fingerscrossed:
  17. Jul 31, 2018 at 7:59 AM
    TC_Mic
    my amber is going strong. Put it on truck March 2017, less than a week after I got the Taco.
    BT17 and TrdTaco171991[OP] like this.
  18. Jul 31, 2018 at 8:00 AM
    sentrychief
    sentrychief New Member
    2017 Inferno TRD OR 6MT DCSB
    Amp Research power steps (75162-01A) Baja Designs Squadron-R Sport LED for fogs (580003) wide cornering Redline Tuning Hood Struts (21-27015-02) Bed Cover BAKFlip MX4 16+ Tacoma 5ft w/ Deck Rail System (448426) OEM Bed lights LED interior and backup lights Salex Glove box organizer OCD Fontic Center Console organizer ARB Differential Breather Kit (170112) OEM Bed mat (PT580-35050-SB) Pop & Lock Power Tailgate Lock (PL8535) Headliner patches
    yes.... it blocks the spare tire access hole!!!
  19. Jul 31, 2018 at 8:18 AM
    necrodiety
    Orlando
    Been considering the opt-7 but saw that lag for the blinker. Hoping they redesign it to work instantly with blinker.
  20. Aug 1, 2018 at 6:35 AM
    TC_Mic
    The delay is because the light bar has to seperate the signal for brake and turn. The bar uses the 4 wire trailer plug so the same wire carries both signals. Essentially the bar must give the signal time to hit the blink cycle to determine if it is brake or turn.
    The only way, that I can think of, to change that is to get the source signals from separate wires. I am not sure but the 7 pin trailer plug also carries turn and stop on a single wire (per side). So in order to get separate signals several taps to the tail wiring or "T" harness would need to be made for every truck model it might be put on. That is not cost effective, lots of R&D and a different kit for each make of truck, and would drive the bar cost way up.
    TrdTaco171991[OP] likes this.
