LED Tailgate Bar
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TrdTaco171991, Jul 29, 2018.
  1. Jan 13, 2022 at 9:35 AM
    #81
    number1stunna
    number1stunna Active Member
    2016 TRD Sport
    Yep, get the 48 inch. It fits perfectly.
  2. Jan 13, 2022 at 11:31 AM
    #82
    316sherm
    316sherm Well-Known Member
    South Louisiana
    2020 Tacoma SR TSS Package 4 Cyl
    So if I have a flat 4 pin trailer connection, is the Opt7 plug and play?
  3. Jan 14, 2022 at 1:24 AM
    #83
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    If you do not want reverse to work on the bar... Yes
    The 4 pin trailer plug does not carry a reverse signal and the Opt7 with reverse has a white wire ready to use for the signal. It will require getting the reverse signal from someplace. Either one of the reverse buckets, the 7 pin connector, or as I used the Curt t-harness. IF you add the T-harness all of your wiring can be hidden behind the bumper and under the truck.
    Choosing a 5 pin plug you get reverse and only need to add a bullet connector the end of the light bar's wire.
    I hope that clears things up for you.
    Watkinseli91 and number1stunna like this.
  4. Jan 14, 2022 at 8:09 AM
    #84
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    The effort that it would take to install a 5-pin, it would be easier to directly wire a tail bar.
    My humble opinion, there's no reason to install a 5-pin flat - its such a rare connector. Most trailers that have five wires will just use a 7-pin RV these days.
    daveeasa likes this.
  5. Jan 14, 2022 at 8:11 AM
    #85
    316sherm
    South Louisiana
    I just noticed they don't make a plug and play 5 pin. That's why I deleted my post. I was just hoping to find a plug and play setup. I don't like messing with existing wires. I may just do without the reverse lights.
  6. Jan 14, 2022 at 8:23 AM
    #86
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Just wanna update my opt-7 light bar is still going strong after 1yr 1/2
    ronmat and RedDemolisher like this.
  7. May 9, 2023 at 1:04 PM
    #87
    Yoda_Mike
    Yoda_Mike YotaWerx Authorized Tuner
    Michael
    South Glens Falls, NY
    2019 Tacoma TRD Sport
    YotaWerx Blackhawk 2.0 tuned. Typer Auto tail light guards. Rough Country tri-fold tonneau cover. Start-X remote starter. Injen CAI. MBPR Armor Plus high clearance exhaust.
    Reviving an old thread here, as I consider this mod for Tacoma. Does the reverse light further wash out the backup camera image, as the plate lights tend to do when upgraded to LEDs?
  8. May 9, 2023 at 3:09 PM
    #88
    TC_Mic
    As I saw it no.
    I had the lightbar before I put in LED plate lights, and the light from the bar actually helped. When I added the LED plate lights is when the image was washed with way too much light.
    There is also a mod out there to turn off the tag lights when in reverse which really helps the issue from the reports, though I have not tried it.
  9. May 9, 2023 at 3:50 PM
    #89
    Yoda_Mike
    Michael
    Thank you @TC_Mic! Appreciate the feed back, especially on such an old post!
  10. May 9, 2023 at 5:51 PM
    #90
    number1stunna
    2016 TRD Sport
    Yes, it doesn't wash it out and actually provides more light. I will say that my Opt 7 light bar failed just after the warranty expired and they wouldn't assist me. They blamed my wiring, and not their product. This is 3 months after the warranty expired.
  11. May 9, 2023 at 5:54 PM
    #91
    Yoda_Mike
    Michael
    That's a real bummer! I'm actually eyeing the split model someone linked further up in the thread. It's a little cheaper and not having to remove it to get to the spare winch is appealing. It's well reviewed on Amazon.
  12. May 9, 2023 at 5:59 PM
    #92
    number1stunna
    2016 TRD Sport
    Interesting, I may look into that one as a replacement. I actually attached the lightbar with 3M velcro so I could remove it if I needed access to the spare. Thanks for the info!
  13. May 9, 2023 at 6:01 PM
    #93
    Yoda_Mike
    Michael
    HERE is a link to it for ya! I figure I'll attach it with the 3M Dual Lock stuff the other folks here were talking about, so if it fails it's an easy replacement.
    number1stunna[QUOTED] likes this.
  14. Jun 2, 2023 at 10:14 PM
    #94
    ronmat
    ronmat Well-Known Member
    Ron
    Alabama
    2018 TRD OFF ROAD 4WD
    Backwoods Hybrid bumper Billie Bars Hyperax Cargo Basket Mess interior lighting H.F. 12000 lb winch Relentless Tune
    Im looking at the OPT7 48 inch myself, has anyone had to use the TOW package module. I was hoping to use
    just the 7PIN to 4 PIN adapter harness. I was told by a rep. that I needed the TOW package module also.
    I see many folks just using the 7 PIN to 4 PIN harness, can i still my 4 PIN for my trailer and the LED tailgate lights
    not interrupting the use of my Trailer plug?
    Thanks Folks
  15. Jun 3, 2023 at 8:20 AM
    #95
    number1stunna
    2016 TRD Sport
    I used the curt 7 pin adapter and everything was then hidden behind the bumper. I towed a Uhaul trailer and just plugged it in normally to factory trailer plug. Worked with zero issues. I'm not sure what the tow package module is...
    TC_Mic likes this.
  16. Jun 3, 2023 at 9:37 AM
    #96
    ronmat
    Ron
    Alabama
    Do you have a backup camera? Don’t know why this would matter but that was there excuse for it.
  17. Jun 3, 2023 at 1:46 PM
    #97
    number1stunna
    2016 TRD Sport
    Yep, backup camera as well.
    I followed this video for the installation and he mentions the tow adapter so the truck doesn't think it has a trailer installed. I didn't use one and didn't have an problems.
    https://youtu.be/t7nnIu1GpJo
  18. Jun 3, 2023 at 2:05 PM
    #98
    ronmat
    Ron
    Alabama
    Yep I watched the same video. I did read on a opt7 link that 2019 and later needed the module for GMC/TUNDRA/TACO/ and RAM SINCE IM 2018 I’m gonna give it a run without the module and if I need it I will order it.
    Thanks for the info.
  19. Jun 4, 2023 at 5:34 PM
    #99
    TC_Mic
    Exactly what I did in2017 within 2 or 3 week of buying my Taco. I have towed many times and had no issues whatsoever with or with a trailer.
    The one note I will give is that the silicone that fills the u-channel for the light bar will hold on to dirt beyond a normal washing making it look a bit dull and brown-ish. I have found a quick wipe with a rag wet with alcohol every 2 or 3 months extracts the dirt nicely.
  20. Jun 4, 2023 at 5:53 PM
    #100
    ronmat
    Ron
    Alabama
    Waiting on the light bar to come in. I’m gonna try and leave enough of the opening for the jack tool to let the spare down, may have to enlarge the opening to achieve this? Thanks for all the advice folks. Always open to suggestions!
