LED Tailgate Light Bar
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Railwayrog, Apr 8, 2009.
  1. Apr 8, 2009 at 10:29 PM
    Railwayrog
    Railwayrog [OP] Well-Known Member
    Dammeron Valley, UT
    2019 DC 4x4 Off Road
  2. Apr 8, 2009 at 10:50 PM
    tc2008
    tc2008 Well-Known Member
    Garden Grove, CA
    06 Speedway Blue
    8000K HID light, LED map and dome light, cluster + AC blue, Camburg 2.5 front and rear, Deaver 10 Packs. Satoshi Grille, Eyelids, Carbon fiber hood w/ scoop, BHLM, 285/75/16 km2s, KMC enduros
    I'm selling my PUTCO LED light bar right now for $40 + shipping. It just plug and play into the trailer hitch adapter and for reverse basically splice the wire and tap it into the reverse light.
  3. Apr 8, 2009 at 11:13 PM
    Railwayrog
    Dammeron Valley, UT
    Why you selling it?
  4. Apr 9, 2009 at 5:47 AM
    tdeguzman
    tdeguzman Member
    SOMD
    2014 Tundra CM 4X4 MGM crew
    i got the rampage, it has turn signals (blinks), reverse light, and brake. its pretty sweet and looks great on tacomas. fair price w/install as well
  5. Apr 9, 2009 at 7:05 AM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2018 Tacoma TRD PRO
    I like the way the PlasmaGlow looks even though it does costs more. The Rampage didnt get very good reviews on Amazon, not that its bad but some people had bad luck with it I guess.
    Does it have to be hard wired or does it mean if you use the trailer plug that supplies power as well? Im guessing if the trailer has power from that plug then this light bar would as well.
  6. Apr 9, 2009 at 7:56 AM
    tdeguzman
    tdeguzman Member
    SOMD
    I haven't had any problems with the rampage light and i am going on 4 months of it on the truck.. But the light bar can be either hard wired (highly recommended) and just plugged into the hitch plug. i got mine hard wired because if you hook your trailer up then you have to dissconnect the light bar. So if you hard wire it, both the trailer and the light bar will function. (not like it takes much to unplug it, just makes one extra step)
  7. Apr 9, 2009 at 7:57 AM
    TacoNH
    TacoNH Well-Known Member
    Nü Hampshire
    07 Blue Tacoma 4.0/6speed
    887s, 5100s, Light Racing UCAs, Nitto 285s, Leer Cap.
    how hard is it to wire up trailor lights?
  8. Apr 9, 2009 at 7:58 AM
    TacoNH
    Nü Hampshire
    And/Or what wires are you hardwiring it to?
  9. Apr 9, 2009 at 8:01 AM
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
    i was thinking maybe we can get a group buy going on for one of these products!
    dgerm where are you?............
  10. Apr 9, 2009 at 8:16 AM
    Railwayrog
    Dammeron Valley, UT
  11. Apr 9, 2009 at 8:17 AM
    Banchi94
    Banchi94 Well-Known Member
    Ron
    Parker, CO
    2008 Indigo Blue TRD Sport DCSB 4x4
    ToyTec 3" basic lift
  12. Apr 9, 2009 at 8:17 AM
    Phantom_X-SP
    Phantom_X-SP Rude Boy |><|
    High Point, NC
    08 DC Black Sand Pearl X-SP
    I may be intrested in something like this as well...where is he!:D
  13. Apr 9, 2009 at 8:18 AM
    KMN-BLU
    Destin, Fl
    2018 Tacoma TRD PRO
    X3
  14. Apr 9, 2009 at 9:00 AM
    tc2008
    Garden Grove, CA
    06 Speedway Blue
    There nothing wrong with the light bar or anything it just that I'm getting a high clearance rear bumper therefore I can't keep it because I'm going with offroad lighting in the rear so it has much more output when I go offroading. BTW it's basically a plug and play there's no hardwiring involve, all you do is plug straight up into the hitch adapter and tap the reverse wire into the LED wire so it'll come on whenever you put in reverse.
  15. Apr 9, 2009 at 9:25 AM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
  16. Apr 9, 2009 at 10:41 AM
    TacticalBacon13
    Dunk
    Beech Creek
  17. Apr 9, 2009 at 11:15 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I called plasmaglow directly and thier lines were full. Waiting on a call back or I might try again later
  18. Apr 9, 2009 at 11:44 AM
    DanGer
    Ok i spoke with plasmaglow and they said they don't normally set group buys up but If we have enough interest he can try and get things rolling with a discount. He reccomended we add the firestorm light controller which makes installation much easier. The contoller plugs into the 4-pin tow hitch adapter leaving the only wires to run the constant power and the reverse. Otherwise he says we would have to run the turn signal wires to the front and the brake to the third breaklight since they all share bulbs in the tail lights. So I know its hard to say without a price (remember I am working directly with the manufacturer) but about how many are interested? I can set up a poll if it is easier
  19. Apr 9, 2009 at 11:47 AM
    KMN-BLU
    Destin, Fl
    2018 Tacoma TRD PRO
    Im in, price dependent.
  20. Apr 9, 2009 at 12:20 PM
    TacticalBacon13
    Dunk
    Beech Creek
    x2
