LED Third Brake Light Question (ACLB)
Discussion in '3rd Gen. Tacomas (2016+)' started by jwitt8, Mar 16, 2019.
  1. Mar 16, 2019 at 2:59 PM
    jwitt8
    jwitt8 [OP] Member
    2017 Tacoma 2.7L
    LED underbody/door lights (tied into dome lights)
    Got a question for the lighting experts in here. I want to make the third brake light a cargo light as well. Think this may be a quick, easy way to do so with a clear lens. Whats available otherwise? Would hook the ground and red LED power to the existing wires and run the white LED power to the dome light.
    https://www.amazon.com/dp/B01MDUDG0N/ref=cm_sw_r_cp_apa_i_faxJCb9765GR1
  2. Mar 16, 2019 at 3:00 PM
    Unchained 5150
    Unchained 5150 Well-Known Member
    Rick
    Auburn Ma
  3. Mar 16, 2019 at 3:00 PM
    Unchained 5150
    Rick
    Auburn Ma
  4. Mar 16, 2019 at 3:19 PM
    crashnburn80
    Kirkland, WA
    2015 DCSB TRD OR MGM
    Go Hawks!
    I like the idea. You are on the right track, red to brake light and white to dome. The wiring should be very easy, mounting it in place will be the more challenging part, but assuming the dimensions all fit that shouldn’t be too difficult either.
