LED turn signal problems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 808HITACO, Aug 25, 2017.
  1. Aug 25, 2017 at 12:58 AM
    808HITACO
    808HITACO [OP] Member
    2016 TACOMA SPORT
    Hi, new here got a 2016 Tacoma and started to work on doing lighting on my car, here is what I did and ran into some problems with the led turn signals
    Hid low beams
    Led high beams
    Led front turn signals
    Led rear turn signals
    Led brake
    Led reverse
    The problem is weird my left turn signals don't work only when the headlight is on and when the headlights is off it blinks fine with no hyper flash, I tried a 3 ohm resistor in the rear, tried 6 ohm in the rear and front with no luck but problem is only when the headlights on with the car running. The bulbs I am using is a 30 watt led that uses 6 cree xbd leds if that matters.
    The right side is fine with one 6 ohm resistor in the rear. I even tried to swap out with new bulbs still same problem.
  2. Aug 25, 2017 at 11:11 AM
    808HITACO
    2016 TACOMA SPORT
    Nobody had any of these problems yet?
  3. Aug 25, 2017 at 11:26 AM
    Optimaltaco
    Optimaltaco Well-Known Member
    Dave
    Cochrane, AB
    '17 Tacoma DCSB TRD Off-Road
    TRD Pro - Grill and Rear Tail-Lights OEM Roof Rack FN overland 17x8.5” -6 BFG KO2 Morimoto 2 stroke LED headlights 30” auxbeam light bar Custom built Canopy Readylift 3" spacer kit Deaver 1.5-2" AAL Amber hazard strobe lighting
    what bulb did you put in the rear? if they are 7440 rather then a 7443 bulb that could be the issue. the resistor only prevents hyper flashing. have you tried swapping back to the oem bulb to see if the issue is still there?
    I have not had that issue. I have Morimoto 2 stroke LED low beams and Morimoto LED front turn signals with Morimoto resistors and LED plate lights and have had no issues. I have not put LED bulbs in the rear.
  4. Aug 25, 2017 at 11:30 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Yep messing with LEDs on this truck is a no go for me based on the electrical gremlins i have seen others report on them here.
    Modesto Tacoma likes this.
  5. Aug 25, 2017 at 12:08 PM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
  6. Aug 25, 2017 at 12:25 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Our flasher relays are hyper sensitive to changes. Too MUCH or too LITTLE resistance will both trip the system into not working.
    I suggest remove all resistors and try it. Depending on how much load your LED turn signal bulbs pull..the 3 or 6ohm may not be needed. I am running LED's on every turn signal and required no resistors.
    Toytaco2k17 and daohaus like this.
  7. Aug 25, 2017 at 2:00 PM
    daohaus
    daohaus Well-Known Member
    Duan
    33.960892 -117.575824
    18 TRD Off Road Premium 4runner
    Rotiform SIX OR Toyo Open Country RT
    This is interesting. I read in the sticky LED post how the op didn't have any issues either
  8. Aug 25, 2017 at 3:43 PM
    Optimaltaco
    Dave
    Cochrane, AB
    I have never bothered to change the interior lighting, my last car has all LED lighting and I found it to be a little hard on the eyes.
    I install 12v accessories and dont mind investigating electrical gremlins, thankfully I have had no issues with the LED lighting that I have changed out. Granted I did pay quite a lot for the bulbs and resistors that I do have, so I would hope there wouldnt be any issues haha.
  9. Aug 25, 2017 at 7:40 PM
    Toytaco2k17
    Toytaco2k17 Well-Known Member
    Kenneth
    Chapmansboro Tn
    2016 Nissan Titan XD Pro4x Diesel
    Stock
    What brand bulbs are you using?
  10. Aug 25, 2017 at 8:03 PM
    MESO
    State of Jefferson
    Front turn signal bucket- Phillips ultinon t20
    Headlight side marker turn signals:Radiantz z flex Amber LED strips
    Mirror turn signals: custom cob boards
    Rear turn signals- Radiantz Z flex board
    Toytaco2k17[QUOTED] likes this.
  11. Aug 26, 2017 at 11:23 AM
    808HITACO
    2016 TACOMA SPORT
    Front is a 7440 and rear is a 7443, ill try put the stock bulbs back and and do it one at a time. Still weird right side is perfect.
  12. Aug 28, 2017 at 5:53 PM
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    What's tge verdict? Did you find the gremlin?
    daohaus likes this.
