led turn signals
Discussion in 'Lighting' started by 2013trdgunner, Jul 9, 2015.
  1. Jul 9, 2015 at 3:58 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  2. Jul 9, 2015 at 3:59 PM
    2013trdgunner
    2013trdgunner [OP] Active Member
    2013 toyota tacoma black
    3 inch lift hid headlights led marker lights and trd wheels
    so in that case i should probably get that fixed? @PeeRunner
  3. Jul 9, 2015 at 3:59 PM
    Rich807
    Rich807 Well-Known Member
    Desert SW
    '14 Corolla Commuter - Future '16 Tacoma
  4. Jul 9, 2015 at 4:00 PM
    T4RFTMFW
    Not at all. The CEL is new, right? It came on after the bulbs stopped working?
  5. Jul 9, 2015 at 4:00 PM
    gibby11
    gibby11 Well-Known Member
    Andrew
    Las Vegas, NV
    2nd gens are better, change my mind.
    I know there is a specific relay for the hazards/blinkers that are made for LED replacement bulbs and that is in the cab fuse block somewhere (I'm on break at work and am not able to get a pic of it). I believe nobody makes one for the 2012+ 2nd Gens because they made a new harness (18 pin). I will look more into this when I get home after work if someone hasn't chimed in by then. Sounds like a fuse issue to me though. Did you check both fuse boxes?
  6. Jul 9, 2015 at 4:00 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Some automotive stores test relays. See if their is a store in your area that can test the relay.
  7. Jul 9, 2015 at 4:00 PM
    T4RFTMFW
    Agreed on fuse issue. Or relay. I don't think it's worse than that.
  8. Jul 9, 2015 at 4:01 PM
    2013trdgunner
  9. Jul 9, 2015 at 4:01 PM
    T4RFTMFW
  10. Jul 9, 2015 at 4:01 PM
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Yea, first thing I thought when I saw this was fuses...but if you're 100% sure checked every fuse then the flasher/drl relay possibly. Remove those LED blinkers asap as you most likely bought the wrong kind, I'm guessing they're 3157?
    The tacoma takes 3157 in the rear and 3157CK in the front
  11. Jul 9, 2015 at 4:02 PM
    2013trdgunner
    and yes all fuses are good in both fuse boxes i have not checked the relays i cant find anyone to test them @gibby11
  12. Jul 9, 2015 at 4:02 PM
    T4RFTMFW
    Dick.*
    MTopp likes this.
  13. Jul 9, 2015 at 4:05 PM
    2013trdgunner
    just looked at them and none of them were blown @Rock Lobster
  14. Jul 9, 2015 at 4:06 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    You need to wire in special resistors to run LED turn signals.
  15. Jul 9, 2015 at 4:08 PM
    #35
    2013trdgunner
    im just gonna leave the stock ones in till i get my new headlights how can i fix what damage is already done till i get my new headlights @AR15xAR10
  16. Jul 9, 2015 at 4:09 PM
    #36
    Herniator
    Edmonton
    Without the resistors the bulbs will flash fast. He might have damaged his relay with the new bulbs.
    What happens if all the bulbs are put back to stock condition? Do you still have a problem?
    AR15xAR10[QUOTED] likes this.
  17. Jul 9, 2015 at 4:09 PM
    #37
    T4RFTMFW
  18. Jul 9, 2015 at 4:09 PM
    #38
    2013trdgunner
    ive already read the code and its a p2118 code which is a throttle response code? @Rock Lobster
  19. Jul 9, 2015 at 4:10 PM
    #39
    2013trdgunner
    yes all the bulbs are in and still nothing but my turn signals work just not any of my running or marker lights work @Herniator
  20. Jul 9, 2015 at 4:11 PM
    #40
    T4RFTMFW
