LED vs HID
Discussion in 'Lighting' started by Boosted TRD, Mar 7, 2015.
  1. Mar 9, 2015 at 3:57 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    This has been discussed a million times over the interwebs. LEDs are not as bright as HIDs. In order to accomplish the same brightness you must use at least more than one high power LED per headlight, and then you have the problem with heat management. LEDs are great for aux lights but not for headlights. If you notice the newer cars with LEDs they have at least two LEDs per headlight, sometimes four, to compensate for weaker lumen output from a single LED.
  2. Mar 11, 2015 at 7:16 PM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    LIES, this is the 1st ever thread.:D
  3. Mar 12, 2015 at 4:27 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
  4. Mar 12, 2015 at 4:30 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    LED lights work great for me! Plus they don't need to warm up.
  5. Mar 12, 2015 at 4:53 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Blah blah blah...
    When it comes down to a choice between:
    LEDs:
    A light source that uses relatively low voltage and solid state technology to efficiently produce light by converting electrons directly into photons and can last for anywhere from 20,000 to 100,000 hours of continuous use before they start to dim and contain no toxic heavy metals.
    Or:
    HIDs:
    A light source that uses high voltages to create an electric arc that burns mercury and metal salts in a fragile glass tube that eventually burns out or starts to flicker when they reach the end of their much shorter lifetime, not to mention the fact that the high voltage tends to break down the insulation on the ballasts eventually causing them to fail as well.
    I choose:
    The more efficient, more environmentally friendly, longer lasting one that won't shock you like a bug zapper if you have a break in the wire insulation. :rolleyes:
    Why do you think interior and exterior building lighting, parking lot lighting and street lighting are all being changed to LEDs? :confused:
    Think what you like but HID, Fluorescent and Incandescent lighting are all dying technologies and will eventually be completely phased out. :cool:
  6. Mar 13, 2015 at 4:28 AM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Because if one or many of the LEDs on the PCB fail, you still have many others there. HIDs are one bulb. ;)
