LED wiring (camper, not Taco)
Discussion in 'Lighting' started by Cuffs, Nov 17, 2016.
  1. Nov 17, 2016 at 1:37 PM
    Jrobertson
    Jrobertson Well-Known Member
    James
    green valley (Henderson)
    2010 Tacoma off road. 4x4
    Stock. For now.
    If it's a straight up 12v led you could come next straight to your battery to compare brightness
  2. Nov 17, 2016 at 1:37 PM
    NMroamer
    NMroamer Well-Known Member
    Fred
    Albuquerque
    2015 TRD OR
    Leds have different color temperatures. Brightness varies from blue to very bright white. Check later when it is not so light out. A bed light might not be a white light.
  3. Nov 17, 2016 at 1:39 PM
    Cuffs
    Cuffs [OP] Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    As in touch the light wires to the battery? I can do that.
  4. Nov 17, 2016 at 1:40 PM
    NMroamer
    Fred
    Albuquerque
    2015 TRD OR
    Yes if your are careful not to make a big spark.
    Cuffs[OP] likes this.
  5. Nov 17, 2016 at 1:41 PM
    NMroamer
    Fred
    Albuquerque
    2015 TRD OR
    Check on Etrailer.com to find out the different led colors.
  6. Nov 17, 2016 at 1:43 PM
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    The light on the fuse panel in my teardrop means the fuse blew.
    If you are accidentally wiring the LED in series with the power you could be having issues too. A straight replacement should just work.
  7. Nov 17, 2016 at 1:45 PM
    Cuffs
    Psh. Leads are too short...
  8. Nov 17, 2016 at 1:46 PM
    Jrobertson
    James
    Stock. For now.
    Cant separate the wire a bit? Whats the led bar look like
  9. Nov 17, 2016 at 1:47 PM
    Cuffs
    And with this, we just made some progress!
    Headed to auto parts store. Dammit.
  10. Nov 17, 2016 at 1:51 PM
    Cuffs
    Have to call it a day too. I have a date. With my husband ! I'll be back tomorrow. Fuses and wires in hand!
  11. Nov 17, 2016 at 2:12 PM
    anonemoose
    Bill
    Big Pine, Calif
    PM if you need specific help. I rewired my 'Amish crafted' teardrop - because they obvious know nothing about electricity.
  12. Nov 18, 2016 at 11:13 AM
    Cuffs
    Alrighty. Let's try this again.
    Today's progress:
    Bought and replaced the blown 10amp fuse.
    Touched LED strip leads to the supply wires, we have bright light!
    Attempted to wire in the switch... blew the fuse when I actuated the button.
    Now what folks?
  13. Nov 18, 2016 at 11:22 AM
    NMroamer
    Fred
    Albuquerque
    2015 TRD OR
    Attach one side of the switch to the light and the other side to the wire coming from the battery.
  14. Nov 18, 2016 at 11:23 AM
    Cuffs
    Oh. Duh. I should have seen that.
    Gonna be a bit. Bought only 2 fuses. Blew them both. Gotta get more...
  15. Nov 18, 2016 at 11:36 AM
    #35
    anonemoose
    Bill
    Big Pine, Calif
    You should always carry a set of fuses, I have 5 of every type in my kit for the trailer converter, TV, stereo, refrig, water pump, solar panel - nothing worse that being out in the middle of nowhere and having power issues.
  16. Nov 18, 2016 at 12:29 PM
    #36
    Cuffs
    I had the spares. I burnt them up. Need an active one and also spares. I know this.
  17. Nov 18, 2016 at 12:41 PM
    #37
    Jrobertson
    James
    Stock. For now.
    Also what's the spec on the switch. Does it give any Info
  18. Nov 18, 2016 at 1:08 PM
    #38
    Cuffs
    I know the switch will work (@mattgecko custom made this for me based on his fsntadtic bed lights)
    I'm pretty sure it's operator error on the wiring right now. Just have to get more fuses... and wire it as @NMroamer suggested
  19. Nov 18, 2016 at 1:24 PM
    #39
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Here is a wiring diagram, the switch connects to the power side only and your power and ground will be from the existing socket wires. I would have responded sooner but didn't see you were having trouble until you tagged me.
    The switch is rated up to 14V and up to 5A
  20. Nov 18, 2016 at 1:56 PM
    #40
    Cuffs
    No worries at all @mattgecko !
    This is operator error on my part. And working with a little different wiring than what usually goes on for the bed lights. And my electrical idiocy....and then there's the whole deal with camper/RV wiring being a little different than what's standard...
