LED's causing hyper flash
Discussion in 'New Members' started by Rosco17, Dec 13, 2013.
  1. Dec 13, 2013 at 11:41 AM
    Rosco17
    Rosco17 [OP] New Member
    06 PreRunner SR%
    Where is the signal flasher locted on a 2006 Tacoma, I have added LED bulbs and have hyper flash, I read that I need to change the resistance as the LED have little resistance
  2. Dec 13, 2013 at 11:42 AM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
  3. Dec 13, 2013 at 11:46 AM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Idk about 2nd gens, but on first gens the flasher relay is under the dash by where the driver's left leg goes. You can buy a replacement relay designed for LEDs, swap it for the old one and you're good to go. This is what I did on my truck and it worked great. Super easy.
  4. Dec 13, 2013 at 11:48 AM
    Large
    Large Red
    Welcome bud, just buy a 5 ohm resistor and splice the wiring between the power and signal wiring of the blinkers.
  5. Dec 13, 2013 at 11:50 AM
    MatthewMay1
    Matthew
    Lone Star Republic
    No need to splice anything with my method! :spy:
  6. Dec 13, 2013 at 11:59 AM
    Large
    Large Red
    Details! :popcorn:
  7. Dec 13, 2013 at 12:00 PM
    Large
    Large Red
    Oh wait, you swapped the relay for one made specifically for LEDs, I got you. If there was something like that for 2nd gens that would be the way to go since the resistors get pretty hot..
  8. Dec 13, 2013 at 12:18 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Is that not an option for second gens?
  9. Dec 13, 2013 at 12:20 PM
    Large
    Large Red
    Not sure, there is a trick to grinding down the pin on the OEM relay until the resistance weakens, but successes aren't many of the ones that tried.
  10. Dec 13, 2013 at 12:22 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    That was an option for me, but the replacement relay wasn't expensive so I spared myself the trouble of jacking with it
  11. Dec 13, 2013 at 1:01 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
  12. Dec 13, 2013 at 1:04 PM
    MatthewMay1
    Matthew
    Lone Star Republic
  13. Dec 16, 2013 at 5:19 AM
    Rosco17
    06 PreRunner SR%
    I will get the electronic flasher as this seems to be easier than splicing resistors
    Thanks
