LEDs (Lights) Made Easy: Interior & Exterior
Discussion in 'Lighting' started by mceagle555, Jan 17, 2009.
  1. Nov 13, 2011 at 8:42 PM
    #61
    mainewoodsballer
    mainewoodsballer YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
    Realtruck.com
  2. Nov 19, 2011 at 12:06 PM
    #62
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Thanks for the great info. I'm replacing all the exterior bulbs on my truck with LED's thanks to this post. All except the signal bulbs. Still doing research on my DTRL equipped truck to prevent the hyper signalling.
  3. Dec 21, 2011 at 11:13 PM
    #63
    tALOHAma
    tALOHAma Well-Known Member
    Oakland, Ca
    07 4X4
    Anytime fog mod, debadged, drop in k&n, smoked taillights, led inside and out,
  4. Dec 21, 2011 at 11:49 PM
    #64
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Here's an interior pic to compare cool white LED with stock filament 168 wedge bulb. The LED cool white is a bit harsh at first; does give better light to find things, reading etc. but overall I find the warm white easier on the eyes. (my opinion, and I still kept the LED install) The LED is the 5 surface mount (SMT) LED style.
    hope this helps for someone debating if they should change out the interior lights.
  5. Dec 31, 2011 at 9:17 AM
    #65
    DeadWeasel
    DeadWeasel ಠ_ಠ
    Rex
    Portland, ME
    09 : 4x4 : 2.7L : 5spd
    32" BFG ATs, Removed 2nd air filter, Brighter Reverse Lights, ARE Cap, LED maps/dome, ScanGauge II, zXe headlights
    Newb just ordered dome and map lights from superbrightleds. I guess they haven't given us a coupon code yet? =)
    Thanks for all the pictures!
  6. Dec 31, 2011 at 10:42 AM
    #66
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    superbrightLEDs coupon code for -5% = RE753
  7. Jan 9, 2012 at 3:05 PM
    #67
    DeadWeasel
    DeadWeasel ಠ_ಠ
    Rex
    Portland, ME
    Any pics of the front marker lights with LEDs other than that blue setup?
    Do they get any brighter than that?
  8. Jan 9, 2012 at 3:07 PM
    #68
    Shemicals
    Shemicals Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    subbed for make-a-da-poopa
  9. Jan 15, 2012 at 9:40 PM
    #69
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    168 series amber LED, 5 LED bulb, DRL/Signal light is stock filament bulb.
    the LED marker light is slightly more amber/orange than daytime running light.
    I don't have pic of original as they were burnt out. Overall I am pleased with the LED amber marker.
  10. Feb 12, 2012 at 5:47 PM
    #70
    mikewho
    mikewho Well-Known Member
    NorCal
    07 DCSB
    Bilstein 5100's, OME 885x's, Toytec 1.5 AAL's, shorty antenna x, Trd sport hood, bed extender, ProComp7098's, BFG 275's, K&N filter, black anzo led tails, OEM roof rack, sock monkey bed decal, extra d rings, weathertechs
    Helpful thread!
  11. Feb 12, 2012 at 10:05 PM
    #71
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    LED Taillight install. Overall result of the LED conversion is a more distinct red color, and a much brighter brake light. Install was as easy as a mod can get.
    Test light before closing it up to ensure the polarity is correct.
    pics are for comparison; truck was winter dirty at the time.
    Driver's side is LED, passenger is OEM bulb. longer length of LED bulb was not a problem.
  12. Oct 17, 2012 at 11:11 AM
    #72
    mmcmahan2206
    mmcmahan2206 Well-Known Member
    McCall, Idaho
    00 Tacoma SR5 TRD 3.4L
    6" FabTech suspension 3" body lift, 35x12.50R15 BFG AT T/A KO tires, Mickey Thompson Sidebiter wheels, 4:88 front and rear gears, e-locker, "grey wire mod," Hella driving lights retroed to 55w 8000K HIDs, custom grill, Downey chrome air intake w/ AEM filter, AirAid throttle body spacer, Flowmaster exhaust, Alpine audio w/ 12" RF sub, racing bucket seats, black powdercoated toolbox, smoked out black taillights, black headlamps and corners, red LED interior lights, sway bar removed, rear shock relocation, u-bolt flip mod, 01 center console, Relentless Fab front plate bumper, LED fog lights.
    I did my map lights, 3rd brake light, corners, and am working on the front blinkers. What type/size resistor do I need for the blinkers to flash normal again??
    Before:
    After:
    Maps:
    Brakes:
  13. Apr 3, 2013 at 7:01 AM
    #73
    evilbit
    evilbit Active Member
    Emir
    SLC, UT
    2006 TRD Sport 6spd V6 Access
    Leer 122 shell (high top), 3" OME lift, diff drop kit, Total Chaos UCAs, DeMello hybrid bolt on rock sliders, Pelfreybilt rear bumper with swing-out gate, Pelfreybilt aluminum skid plates (IFS/mid), ARB front bumper w/ custom MLO light pods, Rigid 24" light bar, ARB Air Locker front/back, 4.56 gears, ARB high output compressor with pump-up kit, scuba mod, Smittybilt XRC10 winch with synthetic cable, 255/85/16 BFG MT T/A KM2 on ProComp Rock Crawler Series 87 steelies, Wet Okole seat covers, WeatherTech floor trays, Hypertech Inline Speedo Calibrator, JVC KD-X50BT mechless stereo, LED lights (interior/rear+brake/reverse/front marker)
    You, sir, are a scholar and a gentleman! :)
    Thanks for this great write up, exactly what I was looking for.
  14. May 17, 2013 at 10:13 PM
    #74
    VtotheZ
    VtotheZ Active Member
    Southern Cali
    2013 TRD Sport DBLB
    Can anyone update the OP, or let me know what would fit or recommend something for the 2013. Theres like 30 things to choose from for map lights alone for 2013 Tacos
  15. Jun 9, 2013 at 8:30 PM
    #75
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    That first page/post needs pics!!!
  16. Jun 10, 2013 at 10:01 AM
    #76
    mltaylo3
    mltaylo3 Army Retired
    Dallas, TX
    14 Pre-runner DCSB TX Edition MGM
    HID foglights, PIAA halogens, extang trifold tonneau, weathertech floormats, Alpine sound system
    PM csjumper2003 for a different kind of led called "Cree" that is much brighter and more reliable than these smd lights everyone is trying to sell you. Just one Cree led will beat all these 100+ smd tubes out there--just Google it. Csjumper2003 already has the right sizes for tacoma internal, external, under hood (with pod and switch), etc. and his prices are fair. Not trying to hijack a thread or advertise, don't personally know the guy, just know that many have had good experiences with him and he comes highly recommended. I wouldn't go any other way but cree. Good luck with your lights folks.
  17. Aug 28, 2013 at 3:04 PM
    #77
    Naholo808
    Naholo808 Well-Known Member
    Jordan
    9th Island (Las Vegas)
    2020 4Runner Off-Road
    2020 Toyota 4Runner Off-Road 3inch lift 33s Ko2s Matte black SCS SR8 2013 Tacoma TRD Sport 2wd - Traded In.
  18. Aug 28, 2013 at 9:52 PM
    #78
    rwpage
    rwpage Well-Known Member
    Bobby
    New Jersey
    2013 DCSB TRD Sport
    Outstanding post thank you! Definitely would like to see some updated pictures on the first post (seems the links are broken?)
  19. Nov 21, 2013 at 11:55 PM
    #79
    DJSPEC
    DJSPEC @GuardianAdventures
    Sean G
    Kaimuki,Hawaii
    2011 TRD Sport DCSB 4x4 & 2014 TRD SPORT DCSB & 2016 TRD-OR AC 4x4
    Viper Alarm NorthStar 31 Battery Pelfreybilt Battery Cage OEM roof racks, step sides 35W 6000k HID Fog Lights 35% tint Front windows 5% tint rear windows 2 Sets of Rigid Industries D2 above the valance Duallys on Famous Fabrication's Hood Hinge Brackets Rigid Industries SR2 10" in HoodScoop with C4 Fabrications Hood Scoop Bracket Flowmasters Super 44 series 9942446) Firestone Destination MT/2 295/70R17 Method 702 17” 0 offset Wet Okole Seat Covers OEM Tow Hitch Plastidip Front Valance FoglightMod(Fuel Pump Relay Version) Matt Gecko Truck Bed LED Kit and Sliding Window Security Bar Snugtop Rebel King 2.5 adjustable front and rear Dakar HD Leaf Springs Icon tubular UCA Dirt Kings LCA
    Sub'd thanks!
  20. Mar 2, 2014 at 6:23 PM
    #80
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    sub'd thank you for the info!
