Leer 100 XR Tracks End Cap Removal Issue [SOLVED]
Discussion in 'Tonneau Covers, Caps and Shells' started by Bravo_X-Ray, Mar 21, 2020.
  1. Mar 21, 2020 at 7:15 PM
    Bravo_X-Ray
    Bravo_X-Ray [OP] Well-Known Member
    Blake
    Springfield, Missouri
    2020 TRD OR MT Voodoo Blue
    Hey guys, I was trying to install my Prinsu Cab and Top roof racks today and ran into an issue with the tracks on my leer shell. The Phillips head screws at the end of the tracks will not come out and just spin in place no matter how many rotations I try. I really don't want to tear up my new cap or drill into it to get the end caps off. Any suggestions on what to try? The place that installed it is not open until Monday to ask them, and we all know how shitty leers customer service is.
  2. Mar 23, 2020 at 10:06 AM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    That screw that holds the end cap runs through the roof and threads into a nut in the interior of the shell. If you've got long arms, you could probably reach it to hold while you unscrew the bolt from above. It's sometimes a regular nut that'll need a wrench, and sometimes a big plastic one that you can hold by hand.
    But: removing that bolt will expose that hole through the roof. So be mindful of sealing it back up when you reassemble. Alternatively, you can get track nuts that will drop into the roof tracks without removing the end cap. Not sure if they'd work with the Prinsu, but I would guess yes.
    Bravo_X-Ray[OP] likes this.
  3. Mar 23, 2020 at 6:54 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    It's already spinning in place according to him so it's going to need sealant added before he reassembles it. Any time you remove a screw/bolt in the shell it needs new sealant.
    Have someone get inside and apply upward pressure on it while you unscrew it with a screwdriver (it looks like the head is already getting buggered from a power driver; I'd replace it it if were me).
  4. Mar 25, 2020 at 12:09 AM
    tahoe13
    tahoe13 Member
    cory
    2019 tacoma OR
    @Bravo_X-Ray is there any chance you could do me a favor? I'm about to install rack rails onto my shell and I can't find any information on where to locate the rails. Is there any chance you could measure the distance between the rails and how far back from the cab they are on your truck? Is your bed ling or short? I would really appreciate the help. Your the man!
  5. Mar 25, 2020 at 7:29 AM
    Bravo_X-Ray
    Blake
    Short bed. While talking to Prinsu they said the rails should be anywhere from 36-38 inches apart. Max is 41 inches for a prinsu rack because the mounting brackets get in the way. Unfortunately mine are 42 1/2 inches apart and I just had to order special mounting brackets from CBI to make it work. The end caps start 3 1/2 inches from the front of the cap and the actual rails start 5" from the front of the cap.
  6. Mar 25, 2020 at 7:31 AM
    Bravo_X-Ray
    Blake
    SOLUTION
    It worked, thanks! The bolt is 3/4 inch and I needed a friend to help.
  7. Mar 25, 2020 at 7:42 AM
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    I've got a 100xr on my short bed with factory-installed rails. Happy to go out and measure the placement today if you still need.
  8. Mar 25, 2020 at 7:44 AM
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    True.
  9. Mar 25, 2020 at 4:42 PM
    tahoe13
    tahoe13 Member
    cory
    2019 tacoma OR
    @Bravo_X-Ray your the man thank you for the information!
  10. Mar 25, 2020 at 11:50 PM
    unk
    unk Well-Known Member
    San Jose
    2017 TRD OFFROAD
    FOX 2.5 Factory Coilovers w/resi DSC @fox ———————————————- Camburg Kinetik Series Upper Billet Control Arms @camburgracing ——————————————— FOX 2.5 Factory Shocks w/resi DSC @fox ——————————————— Icon Vehicle Dynamics AAL @ivdsuspension ——————————————— Baja Designs Squadron-R amber fog light kit @bajadesignsofficial ——————————————— RCI Bed Rack @rcioffroad ——————————————— Tepui KUKENAM 4 XL Ruggedized @tepui
    For the short bed what’s the bed length? Shouldn’t there be two options.. long or short. 682552AC-0952-4AF8-9F9A-797E342B6F7C.jpg
  11. Mar 26, 2020 at 7:53 AM
    tahoe13
    tahoe13 Member
    cory
    2019 tacoma OR
    My truck is a long bed but I believe the width and the space from the can should be the same work either short or long. If you dont mind taking measurements I would appreciate it.
  12. Mar 26, 2020 at 7:56 AM
    jbaker1976
    jbaker1976 It's always Taco Tuesday
    East TN
    2015 DCSB OR
    Camper shell with side windoors and bed slider, JL Audio Component Door Speakers, JL Audio Stealth box, Grill Craft Grill, Husky floor liners, Hondo Radio knobs, Predator steps, Remote Start, Pop N Lock, etc...
    Please take measurements. Can you post a pic from the inside? I have a Leer and I am installing rails. I think the plywood reinforcement was molded off center on my camper shell.
  13. Mar 26, 2020 at 1:53 PM
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    Ok, here's some numbers. Leer 100xr (actually a Raider Vagabond Elite, but they're the exact same thing from the same factory and molds), with factory-installed Thule rails. Short bed 2017 Tacoma.
    The inside edge of the rails sit 34" apart at the front end, and 34-3/4" apart at the back end. The front edge of each rail (the rail itself, not the end plug/cap) sits 5-1/2" from the front edge of the shell.
    Photos of the inside. I added the d-rings and cord. Sorry if the whiteboard is in the way, but you can see the placement of the thicker portion of the roof and the mounting bolts.
  14. Mar 26, 2020 at 2:01 PM
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    That's really odd. I'm not sure which is the right options. You're right that Tacoma only has two bed sizes. They've always listed the bed length of the short bed as 60.5", which I'm sure is inside dimensions.
    unk[QUOTED] likes this.
