Leer 100XQ frozen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jsackspot, Dec 29, 2021.
  1. Dec 29, 2021 at 8:04 AM
    jsackspot
    jsackspot [OP] Well-Known Member
    Currently at the resort and able to reach some items but while unlocked, the glass door simply won’t open. Tried earlier in the AM and it was just not opening, though the center lock latch was turning.
    There are some heat guns at the cabin when I get back down, but would it be somehow dangerous to try to force the tailgate open while the glass door is supposedly unlocked and frozen in place?
    Any other solutions? Thanks.
  2. Dec 29, 2021 at 8:05 AM
    justinm2431
    justinm2431 Well-Known Member
    19 TRD OR
    Put help urgent on your tread title may help you get your answer faster.
  3. Dec 29, 2021 at 8:10 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Just let it thaw out if you can
  4. Dec 29, 2021 at 8:10 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I find constant pressure helps. When you stand on ice, the ice melts slightly because the pressure you apply to it. By applying pressure to the door slowly and steady, it should slowly open. This is how I opened all my doors that have frozen multiple times in the cold snap we are currently having here.
    Formidable likes this.
  5. Dec 29, 2021 at 8:22 AM
    jsackspot
    I think it may be the spring latches— a truck neighbor had a similar capper and it looks like the wires just releases the spring latches, so they’re constantly latched, but free to open once the cables are pulled. Is that accurate?
    Will yanking there tailgate with supposedly frozen (but technically unlocked while the center handle is turned) latches do damage?
  6. Dec 29, 2021 at 8:31 AM
    Grossomotto
    2017 4WDV6LB6MT
    There's only one way to find out if you're up for it
  7. Dec 29, 2021 at 8:33 AM
    Schlucki
    Schlucki Well-Known Member
    Rich
    North Dallas, TX
    2020 DCLB TRD OR 4X4 Cement Taco
    A growing list of stuff
    I have had mine stick before when the center handle was turned and the latches were clear of the edges (meaning it should have opened).
    I just kept bouncing and wiggling it while I pulled it and got it unstuck.
    jsackspot[OP] likes this.
  8. Dec 30, 2021 at 6:26 AM
    jsackspot
    Warm water eventually did it.
    skeletron likes this.
  9. Dec 30, 2021 at 7:14 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
