LEER 100XQ - Rail Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PATHFINDER, Jan 24, 2015.
  1. Jan 24, 2015 at 9:48 AM
    PATHFINDER
    PATHFINDER [OP] Well-Known Member
    Dan
    Oxnard, CA
    2014 MGM TRD OR DCSB V6 4x4
    Leer XQ100, Toyota Skid Plate, Weather Tech Vent Shades, Firestone 2407 Airbags
    I purchased a LEER 100XQ and want to install Rails for racks. Is this had to do? Does anybody know the weight rating for the cap?
  2. Jan 24, 2015 at 11:01 AM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    From Leer FAQ:
    When factory-installed on a LEER Model 100XQ, 100XL, 100XR, 100R, 180, or 122, the Thule Aero Bar and Tracker II Roof Rack systems have a maximum load capacity of 150 lbs. When factory-installed on a LEER Model 100RCC or 180CC, the Thule Professional Roof Rack system has a maximum load capacity of 400 lbs. There are other critical factors in safely carrying and securing loads to your roof rack – these factors are explained in the instructions provided by Thule with the roof rack.
    They are not hard to install. http://lib.store.yahoo.net/lib/orsr...k-tracks-60-installation-instructions-pdf.pdf
    I've used ors in the past, good company. http://www.orsracksdirect.com/thule-truckbed-topper-camper-shell-racks.html
    I ordered my XQ with tracks so the installation would be covered under factory warranty.
  3. Jan 24, 2015 at 11:14 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Be sure to seal the bolt holes. My factory installed rack leaked until I pulled it off and used silicone to seal the holes/bolts.
    Also suggest you check the brake light. The gasket on mine didnt even touch the cap, so when it rained or I washed the truck, I had a waterfall in the bed.
  4. Jan 24, 2015 at 11:20 AM
    DanceswithWolves
    Jerry
    Roosevelt UT
    13 DCSB OR
    My tracks were supposed to be factory installed but weren't. The dealer installed mine. The installer laid out painters tape to avoid scratches during install.
