Leer 100xq remote fob unlock Q
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jsackspot, Dec 25, 2021.
  1. Dec 25, 2021 at 11:30 AM
    jsackspot
    jsackspot [OP] Well-Known Member
    I have a new to me (2020+MY, newest model(?), I believe, twist handle) topper I’d like to add the remote unlock to. Is there a standard Leer part or is the Pop and Lock kit enough? The camper also has the appropriate fuse box (and the 12v outlet, but for some reason the dome light doesn’t work).
  2. Dec 25, 2021 at 11:47 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Can't answer on the lock/unlock setup 100% as I haven't seen any newer model 100xq. However, my Snugtop has just a regular solenoid actuator that hooks onto the lock mechanism.
    For the light, check for power at the fuse, at the light, and check if it uses a pin switch on the ground side (if so, verify good ground).
    Also, from having a 100xq on my '07, you want to check the third brake light for a good seal. Mine had an oversized hole cut and the gasket didn't make contact with the canopy, allowing a waterfall to form inside anytime it rained or I washed the truck.
    jsackspot[OP] likes this.
  3. Dec 25, 2021 at 12:11 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Is there power to the fuse box? Check with the parking lights off, then on.
    My first Leer cap's light was tapped into the parking light circuit. I could only turn the light on from its switch if the parking lights were on.
    jsackspot[QUOTED][OP] likes this.
  4. Dec 25, 2021 at 12:23 PM
    jsackspot
    Yes power to the fuse box, continuity up until the fuse.
  5. Dec 25, 2021 at 3:29 PM
    CT Yankee
    CT
    Then I guess you have to check for power at the bulb terminal.
