Leer 100XR or A.R.E. CX topper?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rondo_Taco, Apr 9, 2018.
Leer 100xr or ARE CX
  1. Leer 100XR
    56 vote(s)
    62.9%
  2. ARE CX
    33 vote(s)
    37.1%
  1. Jan 1, 2021 at 10:33 PM
    #61
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    Regardless of the brand of topper, avoiding leaks has a lot to with sealing the bed before you take the truck in for the topper installation. You can't expect the installers to do this work, or at least to do it well.
    The Tacoma bed has three places where water gets in: (1) the large gaps at the front corners, (2) the holes for the fasteners under the side caps, and (3) the holes for the cubby hinges. The first two should be taken care of before the topper installation; the cubbies can be sealed later. There are also three 5/16" drain holes at the front of the bed (and more in the cubbies) that need to be plugged.
    Toyota makes special rubber plugs for the front corners, but includes them only with OEM tonneau cover installations. Otherwise, you can buy them for $30 each. The side bed caps have to be cut to fit around the plugs. Or, you can use a lot of silicone sealant there.
    All three of the bed caps (sides and front) have to be removed so that silicone sealant can be applied underneath them. On the sides, the sealant bead needs to go inboard of the clip holes, so that water that splashes up inside the wheel wells has a path to escape.
  2. Jan 2, 2021 at 4:58 AM
    #62
    motofish84
    motofish84 Well-Known Member
    Tyler
    Leer 100XQ here with a Victory topper rack. I've had it on almost a year. It's 99.5 % waterproof. IMO the 100XQ is the best looking topper for our trucks as it really has an OEM fit and finish. Only thing I like about the ARE over the LEER is their hinge design for the back hatch.
    91290001_10159530456104418_7752237062417_897382ef3b115cafe3e09b9b70982930ebfc4621.jpg 91195418_10159532286249418_7911795569910_a13a5bbf81c99ea8d01da2bc56a81a6e80fde477.jpg
    b_r_o and Superhulk LB like this.
  3. Jan 6, 2025 at 6:16 PM
    #63
    TN1000
    TN1000 Well-Known Member
    2018 metallic silver TRD OR
    Work in progress
    Do you have pics of your rig with the shell... I have a 18 long bed, little lift with 255s toyo muds. Id like to see what you mean. Thanks
  4. Jan 6, 2025 at 6:54 PM
    #64
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    I know I’m not who you asked. But here is a long bed with ARE CX.
  5. Jan 6, 2025 at 7:02 PM
    #65
    TN1000
    Work in progress
    I appreciate that. Can you lock your self in the back when sleeping? I heard you can't with ARE. I'm really struggling between that model and leer 100 XR. There seems to be horror stories on both brands.
  6. Jan 6, 2025 at 7:18 PM
    #66
    Superhulk LB
    Josh
    Oregon
    I’m not aware of a way to lock yourself in. But I am sure someone has come up with something.
    Yes, either brand you will have some issue.
    Tacomas are hard to seal for water proofing. I have had mine for 4 years now and still glad I got it.
