Leer camper shell and interior light wiring
Discussion in 'Tonneau Covers, Caps and Shells' started by cstallings, Apr 26, 2013.
  1. Apr 26, 2013 at 6:12 PM
    cstallings
    cstallings [OP] Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    I just had a leer camper shell installed on my 2013 Tacoma. I failed to check the interior light before I left. Once I got home I realized the light would only come if the ignition key was turned forward. This does me no good. I need it to be wired hot, so it comes on whenever I push the bottom.
    I found where the power wire is connected, but I need help determining a hot wire. It is currently connected to one of the wires going to the brake light. The brake light should be hot since the light will come on anytime the brake is pressed. See the attached pic is there another wire that is hot all the time? I can't find a wiring diagram for my 2013 Tacoma.
    Thanks
  2. Apr 26, 2013 at 7:08 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Interior lights are designed that way, so they don't kill your battery when you forget to turn them off. It's very typical to wire them into the brake wires.
    I don't believe there are any "always hot" wires going to the brake lights. The only hot ones would be when you press the brake pedal. And the running lights when you manually switch them on.
  3. Apr 26, 2013 at 7:10 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    I just ran a wire from the battery to the back of the truck. Works flawlessly.
  4. Apr 26, 2013 at 7:14 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    ^this, if you want a constant hot wire, run it from the battery (make sure to use an in-line fuse). I wired mine to the parking lights because they can be turned on when the truck is off, keys not in the ignition but if the lights are on when the ignition is turned off, they will turn off.
  5. Apr 26, 2013 at 8:09 PM
    cstallings
    Arkansas
    That's what I was afraid of. I hoped I could just find a hot wire in the back. It just seems dumb to have to turn the key to get the light on. Guess I'll be running a wire from battery.
    Thanks
  6. Apr 27, 2013 at 6:29 AM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
    You won't think it's dumb when you come out one morning and your battery is dead, because you forgot to turn off the light.
  7. Apr 27, 2013 at 6:55 AM
    cstallings
    Arkansas
    Yea...but I'm a man and we don't make those kind of mistakes:eek:
    Realistically…it will never get used in its current state. But at least I know it was supposed to be hooked up like that. It took them several tries to get the automatic lock working
  8. Apr 27, 2013 at 8:55 AM
    NikonRon
    NikonRon Well-Known Member
    Owensboro,Ky
    2009 Tacoma Access 4x4 TRD O/R Pyrite Mica
    Icons,Dakars, Stubb's Sliders,Four Wheel camper Eagle
    If you have the oem hitch and trailer wire harness then you already have a hot wire back there. Ron
    2012Tacoman and zimdog like this.
  9. Apr 27, 2013 at 11:12 AM
    On An Island
    On An Island Assimilated
    David
    Houston-ish
    '12 Black 4x4 DC LB TRD Sport
    Bilstein 5160 reservoir rear shocks, Bilstein 5100 height-adjustable front shocks, SuperSpring SSA19 leafs, Westin bull bar, KC Apollo Pro 6" spotlights, Leer 100XQ cap, K&N air filter, AntennaX 13" Euro antenna, tailgate washers, spare tire tool guide, Console Vault, FJ silver wheel caps
    Carey, my Leer installer wired mine in hot. You might talk to your installer and see if he'll correct that.
  10. Apr 27, 2013 at 11:13 AM
    cstallings
    Arkansas
    Yep...I found it earlier. It actually shows it in the diagram that covers the receptacle.
    zimdog likes this.
  11. Apr 27, 2013 at 11:35 AM
    shorti
    shorti Well-Known Member
    I ended up buying the Pop and Lock tail gate lock and when I ran those wires to the dash I added a hot power wire for the canopy.
    And if you want you can add some LED light strips to the roof of the canopy and wire that into the switch.
    Pop and lock
    http://www.amazon.com/Pop-Lock-PL8521-Tailgate-Toyota/dp/B00439Q05S
    The Light strips.
    https://www.superbrightleds.com/mor...-flexible-light-strip/1466/510/#a=writeReview
  12. Aug 24, 2018 at 11:22 PM
    4Fitch
    4Fitch Well-Known Member
    Tyler
    Manteca, Ca
    2017 TRD OffRoad 4x4 Big Box
    What gauge wire did you end up using.? Inline fuse.? How did you connect to light in the shell.? Also, i tried that method today and the wire i used instantly starting getting warm. I would assume a 6 gauge wire will work fine but im not sure how to connect a 6 gauge wire to a much smaller wire coming from the harness connect to the light.
