Leer Cap Owners please help me with my custom toolbox
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OZ-T, Mar 8, 2011.
  1. Mar 8, 2011 at 10:40 PM
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    Leer Cap Owners
    I am designing a chest style toolbox that I can use with or without a cap , I need to know the height from the bed to the inside of the cap roof , and would like some opinions on how close to the body shape of the cab that the cap conforms to .
    In these pictures I have mocked up a plywood box to check my sizes before commiting to building it out of aluminum .
    Any comments on the lid open picture in particular , do you feel this will contact the inside of the cap ?
    Could anybody post a pic of the inside of their Leer cap , that would be awesome .
    The front of the box will not remain open , this will be a full chest style box , I was making the mock up from scraps of plywood at work .
    Thanks in advance .
  2. Mar 8, 2011 at 10:53 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    gonna be sweet.
    I'm guessing as it sits right now the corners of the lid won't clear the cap as you open it. But I'm just eyeballing it from your pics.
    Your measurements will be more bulletproof if you get the cap first, then build the box. But you already knew that.
  3. Mar 8, 2011 at 10:56 PM
    OZ-T
    Peter North
    British Columbia
    Ya , thanks Bullwinkle .
    I don't plan on getting a cap till the fall , but I need a toolbox now .
    I have that mockup on a couple of 1 1/2" styrofoam blocks , if I lose that height I think it will improve things , it's either that or nip the corners of the lid , which I think is going to look weird .
  4. Mar 9, 2011 at 9:27 AM
    OZ-T
    Peter North
    British Columbia
    Bump for the day crowd
  5. Mar 9, 2011 at 11:23 AM
    chacotaco
    chacotaco Well-Known Member
    Travis
    Lawrence KS
    2011 SSM TRD SPORT DCLB
    Black Snugtop XtraVision Sleep Deck.
    Go to a cap dealer and take measurements. My cap sits inside the rails a bit due to the attachment system. Your box might also be too wide.
    Cut the corners off the lid (or front 1/3rd) and let them be reversed hinged from the front edge of the box.THat way you can open the top all the way, but still tuck under the lid.
    Make sure to get "windoors" on your lid.
  6. Mar 9, 2011 at 11:38 AM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    Nice box.
    Here's an idea. You said you didn't want to nip the corners...that would look siily. How about recessing the lid opening a few inches from the side edges. Box in the top-sides and the door is shorter than the overall length. This would give you clearance with stright lines.
    ...just a thought.
    Good luck; anxious to see the final product.
  7. Mar 9, 2011 at 11:38 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I can take some measurements when I get home tonight and take a picture for you.
  8. Mar 9, 2011 at 11:41 AM
    stevenstaco
    stevenstaco B A N N E D
    steven
    sacramento ca
    o7 trd sport sr5 4x4/06 4runner sr5 4x4
    1.5 aal,Tacomaworld sticker,Blacked out tail lights,bhlm,.dumped exhaust,relocated 7 pin ,rear diff breather mod,bed lights,hella 500s behind the grill,plastidipped lower vallance,mag light mod,debadged,black billit grill,bedmat mod,airaid intake,vynil armrests and back rests,tailgate theft mod, ipod interface,backseat cargo mod,front 5100s
    cant you just make it flush with the side rails maybe a slide out top
  9. Mar 9, 2011 at 11:42 AM
    macgyver
    Brad
    Canton, GA
    The Leer cap overlaps the siderails slightly in the corners to leave a lip so you can fasten it to the rails.
  10. Mar 9, 2011 at 11:44 AM
    stevenstaco
    steven
    sacramento ca
    :facepalm:
    oh!
  11. Mar 9, 2011 at 11:46 AM
    OZ-T
    Peter North
    British Columbia
    The nearest cap dealer is a day away from me . Interesting idea for the lid , thanks .
  12. Mar 9, 2011 at 11:48 AM
    OZ-T
    Peter North
    British Columbia
    I was thinking along the same lines as you about making the top a bit narrower than the box width .
    Thanks for the input .
  13. Mar 9, 2011 at 11:49 AM
    OZ-T
    Peter North
    British Columbia
    Thanks Mac
  14. Mar 9, 2011 at 11:50 AM
    OZ-T
    Peter North
    British Columbia
    I'm trying to maximize the depth while still being able to have the lid fully open with a cap mounted .
  15. Mar 9, 2011 at 11:58 AM
    TakDwn
    TakDwn Well-Known Member
    PA
    2010 Tacoma DC V6 Shortbed 4x4
    Bili's all around, front 5100's at 1.75", rear TSB w/AAL, 265x75/16 BFG AT, Wheelers steelies Type B 4" bs, LEER cap, Tinted, Relentless hybrid sliders welded, Cab mount chop, Plastic trimming, Sock retros, Mirror lift, Satoshi with old school emblem, WeatherTechs, Mudlaps gone, RedLine hood struts, Fumoto valve, Tailgate clamped, Console organizer, Mobtown Offroad Front Recovery Bar
    A couple months back I was doing the same thing....adding a box to the bed that would work with the LEER cap. I even got some prices from Tuffy to make the 'tool chest', but life and work has been too busy to follow through to the completion.
    FYI - According to my mock up, if you keep the box inside the 'wheel wells' and below the bottom of the factory rails your lid will clear the interior of the cap
    I was planning to bolt the box down into the bed floor, leaving room on each side, and only come up in height to the bed rails. Here were my measurements:
    base/width 42" x height 16" x depth 10"
    The customer service department at Tuffy was great and they sent me a bill of sale for a singe ($423 each) or multiple boxes $180 each for 20 or more).
    They also sent me the pdf....attached here.
    Hope this helps
  16. Mar 9, 2011 at 12:04 PM
    David S
    David S Well-Known Member
    sunny Denver, CO
    2012 FJ 6MT
    What sort of LEER cap? Not sure if they are all exactly the same or not. I have the base model, 100R I think. No windoors or nothin. I can take pics and measurements tonight or tomorrow if you'd like.
  17. Mar 9, 2011 at 12:06 PM
    OZ-T
    Peter North
    British Columbia
    Thank you for your help .
  18. Mar 9, 2011 at 12:07 PM
    OZ-T
    Peter North
    British Columbia
    Not sure , I'm thinking an XQ , but any interior pics of any Leer model are welcome .
    Thanks
  19. Mar 9, 2011 at 12:17 PM
    OZ-T
    Peter North
    British Columbia
    Mac , if possible can you measure the clear room between the cap mounting rails at the bottom , front ?
    That would be overly helpful .
  20. Mar 9, 2011 at 12:26 PM
    macgyver
    Brad
    Canton, GA
    ??? no comprehendo ???
