Left blinker stuck on at times
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CSH_09, Jan 10, 2016.
  1. Jan 10, 2016 at 8:02 PM
    CSH_09
    CSH_09 [OP] Member
    Colton
    09 white Tacoma TRD
    So the other day I noticed that my left blinker was stuck on without me doing anything. Went away shortly, but now everytime I press my brake, it come on. As far as I know, it's just the blinker flasher relay? Really could use help on why it's doing this and need fixed asap.
  2. Jan 11, 2016 at 1:45 AM
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    The first thing I would check is to make sure all the lights are working properly on the exterior. Relays are cheap and easy to replace so it's a good place to start. It could also be a grounding issue, if you have a trailer wiring harness unplug it to see if it solves the problem.
