left front end clunking sound. what could it be??
Discussion in '1st Gen. Tacomas (1995-2004)' started by AK Taco, May 9, 2012.
  1. May 9, 2012 at 9:24 AM
    AK Taco
    AK Taco [OP] Your opinion? Fuck it.
    matt
    Anchorage, Ak/ Corvallis, Or
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    I was driving this morning and noticed a rythmic clunking sound coming from the left front end of my truck. The sounds is only present when turning right amd when i am NOT on the brakes. Ive looked in the wheel well and nothing is hitting but i have no idea whats causing the sound. Can anybody give me an idea of what it might be?? Thanks in advance for any and all advice.
  2. May 9, 2012 at 10:20 AM
    trmarshall1
    trmarshall1 The Least Interesting Man In The World
    Tim
    San Jose, CA
    02 Tacoma 4x4 TRD Supercharged
    4" Pro-Comp Lift, TRD cat back exhaust, grey wire mod, clutch pedal linear spring mod
    Had the same issue on my 98...from what I found, it was worn steering u joint bushings. That may or may not be your issue.
  3. May 9, 2012 at 10:25 AM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Ball joints would be my guess, mine are currently clicking really bad!
  4. May 9, 2012 at 10:46 AM
    AK Taco
    matt
    chrome-free '99 sr5
    Where exactly are those bushings? Is there an easy way to check to see how worn they are?
  5. May 9, 2012 at 10:56 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    A clunk and a click could be two different things. If you clicking is proportional to your speed so if it speeds up and slows down as you speed up and slow down you may need to pull your CV's and check them out.
    Also OP you may have the same problem if you're 4x4. Does the clunking only happen when you're turning? Does it accelerate and slow with your speed?
  6. May 9, 2012 at 11:07 AM
    AK Taco
    matt
    chrome-free '99 sr5
    Yes it only happens when i am turning. But only when turning to the right and changes proportionally with my speed. I am 4x4. And it is a heavy clunk not a click.
  7. May 9, 2012 at 11:12 AM
    trmarshall1
    Tim
    San Jose, CA
    Not real easy to explain, I could show you, but I can't link with my phone. If I get time this evening, I'll try to link something. Also, as another member pointed out, check those ball joints for wear. My 98 was in the AZ desert for five years, they really dried out. Finally failed catastrophically about a year after getting back to Cali. Good thing I was doing about five in a parking lot. The tire ended up on its side up in the wheel well. The impact of dropping the suspension a foot into asphalt was horrific, I dread imagining what would have happened were I going freeway speeds. Good luck.
  8. May 9, 2012 at 11:20 AM
    Warhorseforever
    Will
    Sand Lapper
    My first suspect at something like that are your CV Bearings. Have you check the boots?
    I don't mean to treat you like a noob but I don't know how much you know about cars so this is coming from a non condescending direction as possible while still trying to help you.
    Check this thing under the front end if it's busted it's probably the bearings but it may some other suspension part so jack up the front end put it on jack stands and jiggle the tires around see if there is any noises or movement. By you telling me that it happens when turning right check the LEFT boot/half shafts first.
  9. May 9, 2012 at 11:22 AM
    Warhorseforever
    Will
    Sand Lapper
    And this is a U joint check this for movement. This is the little pole looking thing that goes from the trans to the rear differential, the thing that the tires are mounted on in the back.
    Edit: But because you said that it happens when you turn I don't believe that it is this.
  10. May 9, 2012 at 11:29 AM
    trmarshall1
    Tim
    San Jose, CA
    WarHorse, do you happen to have a pic of the steering shaft u joints? That's the issue I had.
  11. May 9, 2012 at 11:30 AM
    AK Taco
    matt
    chrome-free '99 sr5
    I was looking at my cv boots a week or so ago when changing my tired and noticed there were a bunch of cracks in them. No full rips or tears but definitely cracks. Ill check them again as well as the ball joints for excessive play. I have access to a lift locally so i should be able to get under it and check everything out.
  12. May 9, 2012 at 11:30 AM
    Warhorseforever
    Will
    Sand Lapper
    Whoops I just read U-Joint. Yea I'll find one or take one.
  13. May 9, 2012 at 11:32 AM
    Warhorseforever
    Will
    Sand Lapper
    A little bit of movement is fine, 1/4 to 1/2 inch, anymore than that is a problem.
  14. May 9, 2012 at 11:32 AM
    AK Taco
    matt
    chrome-free '99 sr5
    Now i feel like an idiot. I know what a u joint is. I was just over thinking it for some reason :rolleyes: thanks for the pic and explanation tho.
  15. May 9, 2012 at 11:34 AM
    AK Taco
    matt
    chrome-free '99 sr5
    Ill keep that in mind. Thanks!
  16. May 9, 2012 at 11:37 AM
    Warhorseforever
    Will
    Sand Lapper
    It's alright. Like I said I don't mean to sound condescending at all its just that because I'm not there looking at it myself and able to point things out I have to be basic and descriptive.
  17. May 9, 2012 at 11:38 AM
    Warhorseforever
    Will
    Sand Lapper
    Here's the steering shaft U-Joint it's at the bottom of the shaft right at the fire wall above the pedals.
    Edit: It'll have a cover over it to keep crap out but there should be little to no movement in the steering rods and joints.
  18. May 9, 2012 at 11:41 AM
    AK Taco
    matt
    chrome-free '99 sr5
    No offense taken. Totally understandable. Thanks again for all the info
  19. May 9, 2012 at 11:47 AM
    Warhorseforever
    Will
    Sand Lapper
    Look and see if there is any grease around them or on the boots. Like I said give everything a wiggle hands at the 3 and 9 o'clock jiggling side to side, front to back, in and out and do the same at 12 and 6.
  20. May 9, 2012 at 11:55 AM
    Fast_Freddy
    Fast_Freddy Well-Known Member
    99 Black PreRunner
    ome suspension lift, Borla catback exhaust, S-runner bucket seats
    I had the exact problem, mine would clunk when turning right, specially when going up a driveway. I read a thread somewhere where someone had the same problem and it turned out to be the lca bushings. I just finished replacing mine two days ago and haven't heard the clunk yet...will report back after more time. Btw, replacing the bushings was a nightmare, the sub cam assembly was seized into the bushing sleeve and had to be sawzalled out...even if that doesn't take care of the clunk, my whole front is a lot more stable now (bushings had 275,000 miles on them) and I can finally align the truck...
