Left front end pings when going over speed bumps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DeltaBravo, Nov 9, 2018.
  1. Nov 9, 2018 at 8:27 AM
    DeltaBravo
    DeltaBravo [OP] Do you know what nemesis means?
    Waste Management's residential dumpster rental allows you to quickly find the right size dumpster for your project, schedule delivery and pay, all in just a few steps.
    The vehicle commonly referred to as "The War Rig" is a 78 foot 18 wheeler based on a Tatra T815
    Yea that’s the same here. Sometimes I get it at the top of the bump, others at the bottom of the bump
  2. Nov 9, 2018 at 8:28 AM
    tcjacado
    tcjacado Well-Known Member
    That's was my next one to mention. Skid plate.
  3. Nov 9, 2018 at 8:28 AM
    Sosk
    Sosk Well-Known Member
    Evan
    Vancouver Canada
    2018 TRD Sport
    ripRavioli likes this.
  4. Nov 9, 2018 at 8:30 AM
    tcjacado
    Could be the body/cab mount bushing.
    Fitzwilly likes this.
  5. Nov 9, 2018 at 8:34 AM
    ripRavioli
    ripRavioli Well-Known Member
    Evan
    SLC
    2017 Tacoma Access cab 4cyl 4x4
    you said your was your aftermarket skid plate correct? im running stock and have the noise... feel like it cant be a skid plate if im just getting the noise in the snow. Let me know if you make any headway though. I guess ill have to wait to see if it decided to fix itself over the summer? Ha
  6. Nov 9, 2018 at 8:35 AM
    ripRavioli
    Evan
    SLC
    yeah but youd think it would make that noise on every big hit. but it just happens on snowy roads for me
  7. Nov 9, 2018 at 8:37 AM
    ripRavioli
    Evan
    SLC
    yeah, i assume you can feel that through the floor as well?
  8. Nov 9, 2018 at 8:38 AM
    DeltaBravo
    That’s a bit more extreme than mine. I might have to try doing the same
  9. Nov 9, 2018 at 8:40 AM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    That is exactly the noise I have. Hopefully mine is the same diagnosis.
  10. Nov 9, 2018 at 8:40 AM
    tcjacado
    I have a clank again.... I had changed all my suspension and it went away. I returned to stock and now the noise is back, only over speed bumps. But it's not every time.
    ripRavioli[QUOTED] likes this.
  11. Nov 9, 2018 at 8:41 AM
    Michael156
    Michael156 Member
    17 Tacoma TRD Sport
    Have the same problem and took mine to dealer. Told me There’s a lower control arm washer that gets bent and makes the noise but Toyota has not came up with a solution. Waste of time that place is.
  12. Nov 9, 2018 at 8:43 AM
    Sosk
    Evan
    Vancouver Canada
    2018 TRD Sport
    ever so slightly maybe
  13. Nov 9, 2018 at 8:44 AM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    i have this same ping when going over a speed bump with decent speed. I can hear the ping and almost feel it through the brake pedal.
    DeltaBravo[OP] likes this.
  14. Nov 9, 2018 at 8:45 AM
    orangeracer
    orangeracer Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
    I took my 18’ back to the dealer within the first month for a similar noise in the same area when going over bumps. My dealer couldn’t figure it out. I swapped to full Mobtown skids now and it stills there sometimes so I know it wasn’t the stock skids. I feel it mainly in the gas pedal. My sounds makes a “boing” sound with it too usually and happens mainly on slow lefts with hard bumps. Only happened once off road, which was recent. Mainly happens when making a left over the dip into my community. I thought I read a thread that said it may be ABS system doing a self test/check??
  15. Nov 9, 2018 at 8:45 AM
    #35
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    For all of you, torque those Lower control arm alignment cam bolts/nuts to 130ft#'s and 99x out of 100, your problem will go away.
  16. Nov 9, 2018 at 8:46 AM
    #36
    DIRTT_Fish
    DIRTT_Fish Well-Known Member
    2017 TRD OR DCSB
    Cbi t3, 888, HD Dakar, b110, wheelers bumps,ubolt flip, spc uca, +4" rear brake lines.
    If you had new tires mounted or had the tire off the wheel to do maintenance, I had a tech leave a damn valve stem cap inside my tire and mounted it that way. Ticked and pinged like crazy, drove me drove me insane for a week. Crazy right??
    And like someone else said check sway bar and endlinks.
  17. Nov 9, 2018 at 8:47 AM
    #37
    ripRavioli
    Evan
    SLC
    Right on, ill have to give it a whirl.
  18. Nov 9, 2018 at 9:59 AM
    #38
    DeltaBravo
    ... not to sound like a noob... but.... how... and with what... :anonymous:
  19. Nov 9, 2018 at 10:03 AM
    #39
    T6A1C9O
    T6A1C9O Well-Known Member
    San Diego, CA
    2017 SW DCSB TRDOR 4x4 w/Tech
    Had this same symptom coming from the same area for a while. I have not heard anything since replacing my OEM shocks 7-8 months ago. I don't know if it was something internal to the shocks or an installation issue but it seems to be gone. I did the installation and torqued everything to spec myself before getting an alignment. Used a 150 ft-lb torque wrench and pulled like hell.
    https://www.homedepot.com/p/TEKTON-1-2-in-Drive-Click-Torque-Wrench-10-150-ft-lb-24335/205539235
    tcjacado likes this.
  20. Nov 9, 2018 at 10:21 AM
    #40
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Are you asking how to torque them? For 3rd gen Tacos, you'll need a 22mm socket and a torque wrench that is capable of going up to 130ft#'s
