left front fender well tank??
Discussion in '1st Gen. Tacomas (1995-2004)' started by makou99, Mar 30, 2013.
  1. Mar 30, 2013 at 11:04 AM
    makou99
    makou99 [OP] Well-Known Member
    Marc-Andre
    Edmundston
    96 Tacoma
    what is that for and can i just block it, [​IMG]
  2. Mar 30, 2013 at 11:16 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    edit: for correction
    Dirty Pool gets credit
    for the correct answer in his post.
    ADD vacuum tank
  3. Mar 30, 2013 at 8:32 PM
    makou99
    Marc-Andre
    Edmundston
    96 Tacoma
    do i need that ?
  4. Mar 30, 2013 at 11:20 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yes. It's part of the EGR system.
    Unless you delete the whole system. Which is a PITA without removing the motor.
  5. Mar 31, 2013 at 8:05 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    That is a vacuum accumulator tank for the ADD system. It allows for a steady constant vacuum to the ADD VSVs. At least on a 99 V6 it is. Follow the hose back to see for yourself.
  6. Mar 31, 2013 at 12:46 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    ^ yer right and I was wrong.
    * previous post edited to reflect
    If the vacuum cannister is fubar...
    wouldn't the ADD fail to engage/disengage ?
  7. Mar 31, 2013 at 12:50 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    EGR and EVAP are two separate systems dudeeeeeeeeee
  8. Mar 31, 2013 at 1:03 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    don't blame him...
    it's probably my fault for posting incorrectly
    Dirty Pool pointed out my unthinking booger...
    and I edited my original post for correction.
    sorry I posted the wrong info :eek:
    OP
    [FONT=Arial,Helvetica]"If the ADD system does not properly engage the front drive mechanism, the first items to check are the vacuum supply hoses. First, look under the hood and locate the ADD solenoids. Ensure that the vacuum hoses are connected to the solenoids or vacuum switching valves (VSV) as they are commonly called by Toyota. Next, look at the hoses at both the differential and vacuum reservoir located in the R/F wheelwell. Make sure all hoses are connected and not torn, cracked, or otherwise in poor condition. Once the system is engaged or disengaged from 4WD, it will stay in that position. Basically, if the system is not functioning, the vehicle can be placed in either 2 or 4 wheel drive manually with a vacuum source for testing. If you plan to leave the ADD system disconnected you will need to apply vacume from the engine to make sure the front end does not unlock."
    fm: http://www.off-road.com/trucks-4x4/tech/the-automatic-disconnecting-differential-system-19259.html
    [/FONT]
  9. Mar 31, 2013 at 7:14 PM
    makou99
    Marc-Andre
    Edmundston
    96 Tacoma
    I unplug the hose from the vacuum cannister, and and everything still work so i might try to plug the hose or relocate with small plastic canister in the hood
  10. Apr 1, 2013 at 10:28 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Yep, I wouldn't want to think what Toyota gets for that tank. A short scrap of 3" PVC or ABS pipe with 2 end caps. Epoxy in a little tube for the vacuum hose and you will be good to go. Heck, with just a little effort it could be made to look stock.
    The system should work well enough with the hose off and plugged at low throttle (high vac). The whole point of the tank and the little check valve right after the vac source is to provide vacuum when the engine is not making enough on it's own (lots of throttle). Kind of like a "vacuum battery".
    If the ADD system is working with the hose open there may be a clog somewhere. When that tank first got a hole there would have been a vac leak that could have sucked in some crud and plugged something up. Might be a good idea to check.
  11. Sep 1, 2016 at 3:30 AM
    Spence8818
    Spence8818 Active Member
    1996 Toyota Tacoma V6 4x4 391,000km
    Hey I know this is a pretty old thread, but has anybody ever had any luck finding an aftermarket vacuum tank on ebay for this truck?
  12. Dec 28, 2024 at 7:46 AM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    Does anyone know the part number for this accumulator?
  13. Dec 28, 2024 at 10:06 AM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    HOLY OLD THREAD BUMP BATMAN
    might want to fill out profile so members can get tht part# for you
    Yr/engine/tranny
