Left Lower Ball Joint Replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pismo, Nov 26, 2011.
  1. Nov 26, 2011 at 4:25 PM
    Pismo
    Pismo [OP] Active Member
    Tasha
    California
    06 Tacoma PreRunner TRD
    3" Spacer Lift, 17" dick cepek dc2 wheels, 265/70/17 bfgoodrich rugged terrain t/a, ipod adapter w/ stock stereo, jdm headlights & taillights, roof racks, side steps, exhaust tip
    I don't know too much about ball joints, but I believe I need to replace my left lower ball joint because not only is my alignment to the left off but it looks like the boot itself is ripped. My question is, do I have to? (pictures) And also Do I need to replace the left and right lower ball joints at the same time or not? Thanks!
    left lower ball joint:
    right lower ball joint:
  2. Nov 26, 2011 at 5:13 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    One side at a time as necessary
  3. Nov 26, 2011 at 5:19 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    how many miles are on your truck?
    doesnt necessarily look like the boots are ripped, just some residue oozing out of the bottom which is common and normal. in that situation i would not replace the ball joints, only if they are worn out.
    best way to test if they are worn out is to jack the front wheels off the ground and grab hold of the wheel and shake it vigorously (lol) while looking at the ball joints at the same time. if you can see or feel sloppy movement at the ball joints then it's time to replace
  4. Nov 26, 2011 at 8:36 PM
    Pismo
    Tasha
    California
    Thank you very much! I think I will replace the left lower ball joint and get my alignment done so there will be absolutely no problems. There's a little over 60k on the truck. The guy before me used to do a lot of off-roading.
