Left lower control arm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Jan 28, 2015.
  1. Jan 28, 2015 at 4:48 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello,
    I replaced my left lower control arm today because the bushings were a bit noisy & lately when I braked it pulled to the left. You can actually see the rear portion of control arm shift inward when braking. I bought a new one from Toyota. I still have the same problem. :confused:
    I remember that I had to reinstall the old adjustment sleeve on the front bushing the front bolt goes through it. Do I have to do the same for the rear? I don't remember seeing a bolt sleeve on the rear bushing but maybe I missed it. The old LCA is at my job. I'm gonna check the old part tomorrow but has anyone had this happen before? Is there a bolt sleeve on the rear bushing as well?
    Thanks
  2. Jan 28, 2015 at 7:27 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    i bet you have a bad front caliper causing the pull. one is frozen so the other has to do all the work
