<<Left Rear Speed Sensor Issues>>
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dbeckwith540, Apr 6, 2014.
  1. Apr 6, 2014 at 8:50 PM
    dbeckwith540
    dbeckwith540 [OP] Member
    Drew
    South Windsor, Connecticut
    2010 Black TRD Sport
    - Soft Top Ex-tang Tonneau Cover - 3 inch Pro Comp Lift -Blacked out tail lights and headlights -LED interior lights -Raptor Style Grill
    Lights That Came On In Dash
    - traction control
    - abs
    - parking break
    My Left Rear Speed Sensor Was Throwing These Codes
    -C0215 Left Rear Wheel Speed Sensor Signal Fault
    -U0123 Lost Communication With Yaw Rate Sensor Module
    -U0124 Lost Communication With Lateral Acceleration Sensor Module
    -So I ordered a new sensor plugged it in and the lights didn't go off. So then I unplugged the battery to reset everything, that didn't work. So then I reset the ECU, that didn't work.
    -My mechanic scanned the codes again and he thinks it has something to do with wiring. Or a dirty connection somewhere else.
    My Questions Are
    - How many ohm's should a good tacoma speed sensor read?
    - How many volts should be running through the wire to power the speed senor?
    - Where to find a speed sensor wiring diagram? Already tried google images.
  2. Apr 7, 2014 at 2:47 PM
    rhavin42
    rhavin42 Well-Known Member
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    this might help
  3. Apr 9, 2014 at 11:31 AM
    dbeckwith540
    Drew
    Thank you this is perfect.
  4. Jan 21, 2019 at 3:22 AM
    PErsing
    PErsing Well-Known Member
    Paul
    Southern Maine
    2012 Tacoma TX pro
    Caliraised 52" curved lightbar, Fox Shocks, TacomaBeast projector headlights
    Just had this same problem. Got a bunch of snow here and maybe I was losing traction for a long period of time and that screwed something up? It’s also -5° and maybe something’s frozen.
  5. Mar 28, 2020 at 8:14 PM
    Dillonbr
    Dillonbr New Member
    I have the same problem. I replaced the wheel bearing and abs sensor. The light stayed on even after I tried to clear it. Tested the work I did with the opposite abs wiring (plugged the right side into the lift sensor)it read the sensor. Bought a new harness for the rear ABS, still saying it’s c0215 code. I’m lost on what to do now
